Announcement
Collapse
No announcement yet.
Tire Pressure?
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Tire Pressure?
    OK, well i just got a new tire and it says the lowest amount of pressure is 35 and maximum of 65 pounds (250-450 psi) and i put 35 pounds in but it might be to stiff, i was wandering what you guys have, also better hard or stiff for jumping around?
    Thanks
  • #2
    It's a preference, if you have a hard tire it will be harder to compress it but you will jump higher. If you have a low pressure tire, it will be easyer to compress it but you wont jump super high. I hope it helps.
    Jakob F.
    Comment
    • #3
      The thinner your tyre, the more likely it will be for it to bottom out while jumping around with a low psi.
      ~Benjamin
      ><>Unicycle For Christ<><
      No matter how great your triumphs or how tragic your defeats, approximately one billion Chinese couldn't care less.
      Comment
      • #4
        My tire pressure is 2 bar and I weight about 60kg...
        you need to chearch your own tyre pressure... you can't jump 110cm with only 1bar.. but if you aren't a prof and you just can jump like 50cm or so.. 1bar can be perfect
        just try some pressures and you will see what pressure is the best.( do gaps+sidehops..)
        Sponsored by Municycle.com And IMPACT UNICYCLES!!
        Last street vid
        summer street 2010
        last trial/street vid: Tim Desmet- end of 2010 unicycling!
        Impact vid: http://vimeo.com/34332607
        Comment
        • #5
          just put it to a high pressure, get on, and try to compress the tire (push down), if you cant, take a little air out, repeat. Eventually you'll find a pressure that works best for you
          Comment
          • #6
            Just out of curiosity, (maybe im a noob) but what do you mean by bar
            Also i tried lowering the pressure to about 25 pounds and it bounces great but now seems harder to move, though personally like it better at 25 pounds than 35
            Comment
            • #7
              Bar is the unit that is used to measure the amount of pressure under water I think.
              Sam
              Comment
              • #8
                1 bar is about 14.5 psi. I'm not sure how it relates, but there used to be a unit of pressure called an atmosphere that was also about 14.5 psi, and for some reason the bar is what is used anymore.
                So, 2 bar's is about 29 psi.
                "A properly ridden unicycle is like an object in orbit: constantly falling but never landing." -Diogenes
                Comment
                Working...
                X
