Announcement
Collapse
No announcement yet.
Yet another freemount post
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Yet another freemount post
    Iíve been successfully riding uni for three weeks now and but my main frustration is that I just canít seem to suss out the freemount with the cranks in horizontal position. Every time I step onto the dominant pedal the cranks swoop vertically immedately, making placing the other foot almost impossible. Iíve watched videos and uni colleagues freemount and their cranks always remain horizontal... how do I achieve this? Surely any pressure on the pedals results in the cranks turning. Should all the weight be on the saddle? I can sometimes achieve a successful freemount with cranks 7 oíclock but the wheel still kicks back and the vertical position makes riding forward tricky. I own a UDC Trainer 20Ē with 6Ē cranks.
    Constructive criticism welcome!
    stag
    "Einstein was right."
    "Einstein was probably one of them."
    (Close Encounters of the Third Kind)
    www.eddify.com
  • #2
    The best way I can describe it was mentioned not too long ago. If you have ever stepped on a little kid laying on the ground, you don't put any weight on that kid or else splat. Step on your dominate pedal like that. NO weight. Hop up and when both feet are set, go. My issue is placing my second foot correctly on the pedal. If I am trying to mount uphill I often place my foot too far forward/backward/in/out. I hope that will get better with experience.
    Comment
    • #3
      Static mount:
      Don't step on that back pedal. Just hold it in place with your foot. Then "hop" up onto the forward pedal.
      Roll back mount:
      Step on that back pedal and push it enough to roll the wheel back past the vertical pedal position. Then place your other foot on what was the forward pedal and is now the back pedal.
      You seem to be doing something that is exactly in between these two successful techniques.
      -Greg Harper
      Nipples...do you ever have enough?
      Change is good. Bills are better.
      Comment
      • #4
        Stag
        mbalmer's advise is good - that's basically how I got it! If you haven't already done so, use the search as there is lots of great advise out there.
        Believe me - I think the freemount is harder to learn than learning how to ride.
        Cheers
        Simon
        Comment
        • #5
          Thanks guys, I will take the advice on board. If you can do it so can I!
          stag
          www.eddify.com
          Comment
          • #6
            Step on to the back pedal as if you are trying to step on to a road cone without it folding
            Team Dirty Needlez
            Grouse.
            Brian O:
            Its just a boob, get over it.
            Comment
            • #7
              You could try stepping onto the crank and putting your weight near the hub, and then when you put your front foot on and start riding just slide your back foot over to the pedal.
              Comment
              • #8
                I cheat. I kinda push the uni forward when I mount so I can put some pressure on the pedals.
                Comment
                • #9
                  It's easy Mate
                  Say you're a pirate who got his leg shot off with a cannonball above the knee. So now you got's a peg leg . Your parrot talks you into riding a unicycle, so what do you do ?
                  Sit on the uni with the left pedal back, unless you had your right leg shot off, whereas you should reverse these instructions.
                  Put your wooden leg on the left pedal. Jump forward with your right foot onto the right, forward pedal and ride off. One footed I guess, but seriously I have seen pirates do harder tricks than that.
                  The point here is the pirate just blocks the left pedal with his wooden leg. He can't step on it. He blocks it so the uni doesn't roll forward while his right foot makes the jump to the front pedal.
                  Comment
                  • #10
                    For a static mount I usually put my dominant (right) foot on the pedal, grab the seat bumper with one hand and hold it in place. I then jump UP and forward and put my other (left) foot on the pedal. My momentum should carry me forward. As I start to lean forward I begin to pedal.
                    Here are a few points:
                    As everyone else has said, put essentially no weight on the back pedal. Your foot is just positioned over the pedal to keep the unicycle from rolling backwards.
                    I hop up and forward. The UP part is important because it keeps me from leaning on the back pedal and shooting the unicycle back under me.
                    It sometimes feels like I pause after the jump to let my weight move forward. Until you are leaning forward you cannot pedal forward, so a very brief pause can help your mount.
                    Wear shin guards! (I can show you my scars.)
                    Here is a video I found helpful when I was learning to mount:
                    [ame="http://www.youtube.com/watch?v=boJoCeKslXo"]YouTube - How to Free Mount a Unicycle[/ame]
                    Comment
                    • #11
                      Aaaarh
                      I'm another very frustrated freemounter. My body just wont learn, and when I do get on I'm all over the place!
                      Will try the technicques described
                      How long is reasonable to learn to freemount? I've been at it a good month now.
                      Comment
                      • #12
                        That's not cheating; it is a perfectly good technique.
                        Seat firmly in place, right hand on handle, left foot on pedal at just below horizontal. Slight push forwards so that the pedal tries to rise against the sole of your left foot, and sort of "pole vault" into the vertical position.
                        This gets you in the riding position with the cranks more or less horizontal, and the wheel either stationary or travelling slightly forwards.
                        Far better on uneven surfaces than a roll back.
                        My first novel, Bridge of Otherwhere, Michael Wilkinson, on Kindle. A tale of subtle magic, mystery, friendship and love. Tinyurl.com/Bridge-of-Otherwhere For US$ page: TinyURL.com/OtherwhereBridge
                        Comment
                        • #13
                          It took me from 1987 to about 2002 - because no one told me the proper way and I was doing it with the pedals in the 6 o'clock position. I had a success rate of around 25%.
                          Then I found this forum, and someone showed me a better way. Then it was practise practise practise for a few minutes a night for a month or two, as well as doing it "for real" on rides.
                          Then one day, I could suddenly do it.
                          Comment
                          • #14
                            Stag and Shacklersrevenge,
                            If it makes you feel any better, I can ride indefinately (miles) but I can't yet reliably freemount. I did improve my success rate by lowering my seat though. If you do that, just remember to put it back to the proper hight for distance riding.
                            Good luck, I'm right there with you!
                            Level 1 Unicyclist
                            D Licensed Skydiver
                            Level 4 Silly Walker - government grant pending
                            Comment
                            • #15
                              So if I understand you persons correctly that to free mount properly you are "hopping" on the seat rather than applying force with your dominate foot, allowing it to roll back and then bringing up your other foot and going (?)
                              Comment
                              Working...
                              X
