Announcement
Collapse
No announcement yet.
Learning to Mount a 36er
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Learning to Mount a 36er
    1 wheel, 1 day, 100 miles, 64 years...
  • #2
    You're coming along well Geoff! What I do notice though, is that you are not "committing" enough and ALWAYS fall off the BACK. You have to get your CG over the TOP of the uni, and not be afraid to bail off the front of your uni.
    Also I would suggest trying the rolling mount as this will give you some extra momentum and make it easier to get up over the top of the uni. Keep at it you're doing great!
    Happy Birthday Terry! Every year you get cooler, younger and unicyclier!
    Be our muniprohpet for many years more.
    -Dani Buron
    Website
    Videos
    Facebook
    Comment
    • #3
      I watched the first one. I'm about to go out to teach unicycle lessons so I will answer hastily. From watching your video I reckon do not try to hold the T7 while mounting- I've snapped two of those handles and I think it is not designed to take much pressure on it. I hold the KH handle as if the T7 isn't there when I mount, then once I am up I can get my hands out the front for a slightly more comfortable position.
      Buying a standard seatpost may help, but I think you nailed it when you said "I end up not quite on top of the wheel so it is difficult to get it rolling". That is the nature of the Coker beast! It is much taller than any other non-giraffe unicycle, so to get your center of gravity up and over the wheel takes more of a push off with your foot. The more failed mount attempts the harder it gets too! You can start on something a bit higher, like a step or a seat, and you will be able to step on easier without such a big push.
      Keep working on it. What you are doing right is practising, just use a bit more effort and believe in yourself after each fall.
      Comment
      • #4
        For now here are 2 things to try. Sif mounting, hopping going SI riding away, OR Doing that mount, getting into jumping position, and then fixing your shorts.
        661
        MountainUni
        or make it a dinglespeed - saskatchewanian
        Comment
        • #5
          It looks like you have a really hunched over body position, and you're not getting all the way up onto the wheel. I think you just need to practice mounting to sitting straight up and looking forward instead of down.
          Also, you might try holding onto the plastic handle for mounting instead of the T7. If you mount holding the T7, you need to push it out in front of you, perhaps more than you're comfortable doing presently.
          Comment
          • #6
            You're so close to nailing it consistently!
            Another few hours of practice and youll be there.
            It's difficult to tell from the footage but are you on a flat road?
            I always find it easier to mount on a small incline.
            I often feel this is psychological.
            Even when I try and mount on a flat road I tell myself that I am on a small downhill slope just to get in the right frame of mind.
            And congratulations on not swearing out of frustration.
            The beep machine would have gone into overtime if that was me.
            Comment
            • #7
              Really big thanks for a quick reply Terry! Firstly, just to hear am doing OK helps to put things in perspective - because I have no idea if I am or not (unless I get feedback) Secondly....yeah!! I was wondering about 'committing' but hadn't thought of that term for it. I was trying to psyche myself up to 'going further' but until you said it I was unsure. Brilliant! - now that it is clearer to me I will have a different mental approach
              Comment
              • #8
                Thanks for that! Yeah I am on a small incline that runs onto flat ground further on. So I get to try on the slope and the flat. Excellent point about thinking you are on an incline even when on the flat. I think I can 'will-power' that into my mind.
                Comment
                • #9
                  Thanks for advice! Yeah I noticed in the movies I was hunched - didn't realise it that much at the time. What I have noticed is how 'steady' the 36er is with the mass of its large rolling wheel compared to the 24". Will focus on sitting upright the longer I can get into the seat!
                  Comment
                  • #10
                    Originally posted by Rowan View Post
                    .......Keep working on it. What you are doing right is practising, just use a bit more effort and believe in yourself after each fall.
                    Thank's to Rowan and everyone else who provided me with some great feedback to work on. This has really helped to put things in perspective. Gee-Whizz I can't wait for sun-up tomorrow - weather forecast is good, and I have day off work ....now let's get the video camera charged
                    Comment
                    • #11
                      Three major things I noticed, all of which have been mentioned but I'll reinforce them a bit:
                      1. Don't mount from a dead standstill. It's much easier if you have a bit of forward inertia and even one step taken before going for the pedal takes a lot less energy. No need to change any of your lining-up of the unicycle, just hold it farther in front of you and start with the opposite foot. Take one step and then continue from where you are in your videos. This will provide plenty of momentum to take you up and over the top of your wheel.
                      2. Don't hold the T7 handle. It's always harder to hold an extended handle for mounting; they're more useful once you get going. even if there's no bumper there, just hold the front of the seat while getting on, and you'll notice you have a much more secure grip there, and more control for the mount.
                      3. The last bit is to just have a little more "oomph" when stepping up. Most of your unsuccessful mount attempts have you falling back to where you started, which means you're not getting up far enough. The goal is not to hit a perfect balance up there (though that works a lot better with big wheels than with small ones), the goal is to get *ahead* of top-dead-center. With practice, you'll be able to get just a bit ahead of the TDC spot, which will give you more time to comfortably get your other foot on the pedal before you have to start pedaling. But for now, just make sure you're going a bit past TDC for a successful mount.
                      Bonus:
                      4. Put away the camera now. Not that your videos weren't immensely useful! Without video it's very hard to diagnose unicycling riding problems. But now relax and enjoy the riding (and mounting), and feel good about the fact that you've already mastered the hard stuff. In time, the mounts will get more consistent until you hardly ever miss. I've been riding large unicycles over 26 years now, and still miss the occasional mount, especially if I have large handles and/or really short cranks on there.
                      John Foss
                      www.unicycling.com
                      "Who is going to argue with a mom who can ride a unicycle?" -- Forums member "HiMo"
                      Comment
                      • #12
                        When I watched your videos I noticed that on all the successful attempts you used one arm for balancing yourself. When you didn't you mostly didn't make it to the CG. So using your arm seems to be helpful for now. I also noticed that you didn't wear any protective gear. Maybe if you wore a helmet, some knee and shin guards and some KH gloves that could let you commit a little more. I know that always lets me feel a little more confident in general, even if the riding isn't particularly challenging.
                        Since I modified my 36" nimbus with a long handle bar and bike seat my own mounting consistency dropped some. But it seems I have to have one hand on the handle and the other one in the air for keeping myself balanced in the beginning. Then it often works. Another problem I have is I usually fail more often when there are people watching. It's just a self confidence related thing probably. I guess it will all improve over time with more practice.
                        -knee
                        Comment
                        • #13
                          Bonus:
                          Thanks for putting those points perfectly in perspective John I'm all set for tomorrow when I have a free day to practice Just one point about your comment, '...start with the opposite foot'. I read the 'training manual' that said, 'put your dominant foot first'. I find my left leg dominant so I put this first on the pedal. So, you seem to suggest I would be better using my right foot? I did try this - once or twice - and it felt slightly odd. However, should I actually be sticking to a specific leg/foot? I am right-handed so I should use my right foot first? Your point 3 hits it on the head for me and others have reflected this.
                          Most of all I feel very uplifted at getting some advice back on what I am doing since I live in 'unicycle-isolation' in the depths of the countryside. These forums forming the only means I can discover if I am doing something right or wrong when unicycling (apart from inner feelings)
                          PS I've put the camera away
                          Comment
                          • #14
                            What I think John Foss meant was that you should start further back from the unicycle so that you have to take an extra step BEFORE you put a foot on the rear pedal. The point is to get your body moving (to build up momentum) so that it is easier to get on top of the unicycle. I am a relatively fresh/green 36-rider myself so I know exactly what you are struggling with. Just keep at it!
                            Comment
                            • #15
                              Just curious, Jeremy, how long have you been riding 36ers? I don't know any people who hop / jump when they mount... sounds kinda sketch.
                              "The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt." - Bertrand Russell
                              Comment
                              Working...
                              X
