Announcement
Collapse
No announcement yet.
Another broken KH seat... but..
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Another broken KH seat... but..
    Today I broke my KH seat post in half, right where the tube narrows and is welded. Luckily I was just riding on flat ground, but I was still almost impaled
    I've been suspecting that I broke the stiffener plate in the saddle, so I opened the seat up tonight, and sure enough, cracked it in half in the usual place.
    Through searches and all I've decided to buy a Thomson rail seat post and KH rail adapter...
    ...but...
    if I buy that, I certainly don't have enough money for a new seat. I'd love to get a carbon fiber seat base, but they're expensive. I've searched all over, but havn't found any threads about repairing/replacing that metal plate. I'd rather not replace it, just to break it again.... is welding it practical? Does anyone make a GOOD replacement for it?
    Or should I just suck it up and go for the carbon fiber?
    Pissed about breaking a top of the line unicycle, Dave
    "You build a wood contraception that slides over it and has a removable pin at the top to keep it in place" - carsonpalooza
    "o yeah how do i change that thing under my name that says i dont know how to change this?" - habbywall
  • #2
    i don't know if they're available yet, but i have a prototype/first run of a gb4 stiffener plate for the new kh saddles. made the seat about 5x as stiff. when i did the swap i tried to bend the KH and it bent semi easily with my bare hands. the GB4 was definitely not going anywhere without a clamp and a hammer. email george. maybe he's shipping those now/has some in stock.
    Comment
    • #3
      i just threw out the broken stiffener plates and didn't worry about it, seeing as it was broken already (and looked like it had been for some time) I never noticed a difference. (it was always flexy)
      it 'will do' in this mode until your CF replacement
      UnicycleGlidecam.com
      RoundCircleMedia.com
      Comment
      • #4
        I made some 1/8" thick reinforcement plates a while back. They worked great, but they weighed a lot.
        "When life hands you a lemon, say 'Oh yeah, I like lemons. What else you got?'"
        -Henry Rollins
        Comment
        • #5
          How did you go about making one? I have access to a machine shop, and could give it a shot. Did you take any pictures/write instructions?
          Dave
          Comment
          • #6
            I just flattened the existing reinforcement plate so I could get a templet. After that I cut the templet out of 1/8" steel. Then I bent the metal using a burning torch and hammer to the curves and and bends of the original reinforcement plate. Finally I drilled holes for the bolts, put the bolts in, and welded them to the plate to prevent them from spinning. I only took a picture of the finished product.
            That is a comparison shot.
            -Henry Rollins
            Comment
            • #7
              I just took one of my KH seats apart to replace a broken mounting bolt and found the metal plate broken in this same place.
              My thought was to weld a spine along the center, made out of 1/4 or maybee 5/16 steel rod. this would add some extra strength with out all the weight of making the whole brace out of boiler plate.
              When I get around to this project i'll take pics.
              Comment
              • #8
                Al - I like that idea better than a big heavey plate.. let us know how it works out.
                Does anyone know if there is a warranty on my '04 KH Trials, purchased from UDC. I looked all over Kris's site and UDC and couldn't find anything. Anyone know anything about this?
                Dave
                Comment
                Working...
                X
