Announcement
Collapse
No announcement yet.
Magura HS22
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Magura HS22
    Does anyone know if the Magura HS22 will work in a standard Magura frame mount. Are the decent? Help I'm clueless on hydraulic brakes.
  • #2
    I'm 99% positive the only diff in the 33 and 22 are that the brake lever is differnet, and there is no pad adjuster on the 22
    The mounts will be the same for sure
    UnicycleGlidecam.com
    RoundCircleMedia.com
    Comment
    • #3
      oops see new thread. For Sale Maggie H-33....
      No one said it was gonna be easy and I'm not afraid to try, with the odds stacked up against me I will have to fight, One Life One Wheel got to do it right. H2O
      -------MUNI MILITIA -------
      One Wheeled Death Squad
      Comment
      • #4
        Magura make/made the HS11, HS22, and the HS33 with the difference being just the lever, the rest is the same. I have a HS22 (broken now though) that was briefly fitted to my Muni and I have replaced just the lever with a HS11.
        The HS22 is no longer manufactured but the HS11 and HS33 is. The difference between the HS11 and HS22 is that the HS22 has a metal body, the HS11ís is plastic, the HS22 has two adjustment screws, the HS11 has one and the HS22 is the heavier of the two by quite a bit.
        I donít know much about the HS33 other than itís more expensive, it has a TPA knob and has a more powerful master cylinder than the HS11 and HS22 (which are the same power wise). Whether the extra power or the TPA is good for a unicycle I donít know but my set up is more than powerful enough for me and I donít think the TPA would be useful to me.
        Take a look here for info.
        Cheers, Gary
        Comment
        Working...
        X
