Announcement
Collapse
No announcement yet.
Looking for backspin tips
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Looking for backspin tips
    The directions in the IUF skill levels show the following for a backspin:
    1. While riding forwards, slowly turn the upper body 90 degrees left (or right) relative to the wheel's direction.
    2. Quickly twist the upper body 180 degrees (the action), causing the wheel to pivot on its vertical axis 180 degrees in the opposite direction (the reaction).
    3. Recover from the 180 degree wheel snap by slowly returning the upper body to a normal riding position from its 90 degree right (or left) position.
    As I am working on this move, I am not sure when to initiate the move in relation to my feet. Does it matter? Is it best to lead into it with the outside or inside foot? Any suggestions would be appreciated.
    Bill
  • #2
    Thought I'd give this one more shot and bring it back to the top. Can anyone help me or give me a link to go for help?
    Bill
    Comment
    • #3
      i have never even attempted this trick but here is my advice:
      if there is a certain way (clockwise, counter-clockwise) you twist, then twist that way for the first and final 90 degree twists and the other way for the 180. this is so you can recover. good luck.
      The Hell on Wheel Unicycle Gang owns you!!
      http://www.unicyclist.com/gallery/albuq25
      Comment
      • #4
        I haven't tried it either (but I will do after reading this thread), I can see myself stopping and then spinning 180 but to do it and convert your forwards momentum into backwards momentum, you'd have to spin really quick. Hands up who can do this?
        I think oranges were named before carrots
        Comment
        • #5
          Anyone who has passed level 6.
          The IUF skill levels have an explanation of the frontspin and backspin in level 6.
          Hopefully someone knowledgeable will jump in with some additional hints for doing a frontspin and backspin.
          john_childs (att) hotmail (dott) com
          Team Never Wash Your Muni
          My Gallery :: Unicycling Bookmark List :: World Clock
          Comment
          • #6
            Re: Looking for backspin tips
            a while a go i read a fascinatingly technical discussion how to make what is seemingly impossible possible
            i wish i could find the link
            doing searches on front- and backspin might get it
            one thing i do remember was the suggestionthat u dont ride in a straight line but rather a gentle curve to help set-up the momentum for the rotation
            does anyone remember reading this article?
            link?
            Three short Gs and a long E-flat™ - UniHoki
            If I'm Murdered, Don't Execute My Killer.
            harper
            MikeFule Seager BluntRM
            NAMASTE!
            Dave
            Comment
            • #7
              The first post I did shows the tips given for the backspin. But the tip does not mention anything about timing of the spin and the feet. That is my specific question.
              Thanks to all of you who have given your thoughts. I was starting to feel a little lonely.
              Now to wait patiently for a level 6 + rider to share their wealth of knowledge and experience.
              Bill
              Comment
              • #8
                (bump)
                Someone must be able to describe the backspin, please.
                What are the crank positions?
                Or could anyone post/find a video clip?
                .duaner.
                Comment
                • #9
                  Originally posted by duaner
                  (bump)
                  I find when I do a backspin, that I start with my strong foot forward, and as I start the action/reaction turn, I push my strong foot so that it is straight down, and moves a little to the back. Then when I start in backwards I push my strong foot down again to begin the backwards motion.
                  I practiced by starting doing an exaggerated turn where you do a smooth 90 degree turn to stop, then pull backwards out of it to get the other 90 degrees. As you get better the turn gets smaller and smaller until you can do the spin.
                  Comment
                  • #10
                    kewl!
                    THAt listens...
                    harper
                    NAMASTE!
                    Dave
                    Comment
                    • #11
                      I have been having a little success by doing what joshp said. For example I lead into the spin/turn with my right foot while pedaling down into the spin, then use the same foot to start pedaling backwards.
                      Best I have done is more like doing an 90 degree turn in and out of the move. So I am going about a foot to the side to complete the "spin". I've seen videos of freestylers spinning and staying almost in a straight line. To me, that is a true spin.
                      Thanks for your input folks.
                      I've seen a post that was looking for a collection of videos showing the different moves. That would be great! I've seen great sites for footbag and for juggling that do this well. They offer the clips in real time and slo motion. Great teaching aid.
                      I'm sure this type of a site would take a massive amount of time and energy.
                      Bill
                      Comment
                      • #12
                        i can
                        i can backspin pretty well, as i am nearing completion of level 6. when i backspin,(which is a little less smooth than my frontspin) i slow down while riding forwards. when my cranks are in the cranks level position( for me right foot forward) i stand up a little bit, lean back, and lock my legs, using my arms to provide rotation. this ends up with me rotating 180 smoothly while my momentum from riding transfers. by the time i have rotated, the momentum is forward, and i am facing backwards, which i ride out of. i think this is it. if i am doing anything wrong someone tell me. later. Nick
                        "No one is taller than the last man standing"
                        The deadline for all complaints was yesterday.
                        Comment
                        • #13
                          This is where to start. Foot position is not relevant. Regardless of what previous posters have mentioned, to stop (and switch pedaling direction) your feet are going to be somewhere in the horizontal range. You can't help it. If you ride *slow* enough, you can do it with your feet in the dead spot, but the move only really looks good when there's some speed and fluidity.
                          Your object is to get yourself turned around to going in reverse, with as little upper body movement as possible. In other words, your upper body should continue in an unbroken straight line (not counting any arm movements or torso twisting). Of course it has to rotate around.
                          Start slow, by making a 90 degree turn to the side, followed by a reverse 90 degree turn to continue in the same direction. The slow version is like pulling into and out of a tiny parking space. That's what your wheel is going to do.
                          Now gradually work it up to faster speeds. Think about your upper body, and work toward having it continue in an unbroken straight line while the other stuff happens mostly at the lower body area. As you smooth it out, the size of your "course deviation" will get smaller, but it will always be there. It just won't look like it, because your upper body keeps a straight line. Your upper half should continue in a flow, while the wheel "snaps" around to face the other way.
                          To do any trick well, it should look smooth and effortless. Unless it's not a smooth-moving trick. You'll know you've got the backspin where you want it when it *feels* smooth. Then work on the frontspin.
                          I watch the younger and beginner riders do slow-mo backspins in their Standard Skill competition routines. Ouch. Those aren't really backspins. But there is no speed requirement, so pulling into and out of a parking space is technically acceptable.
                          John Foss
                          www.unicycling.com
                          "Who is going to argue with a mom who can ride a unicycle?" -- Forums member "HiMo"
                          Comment
                          • #14
                            Pittburgh riding
                            If I a not mistaken joshp is a Pittsburgh rider. I will be in Pittsburgh next Friday and plan to ride with the Pitt. Campus Fools.
                            http://www.pitt.edu/~sorc/cfools/index/main.htm
                            Probably 6-8 pm
                            Billham you are more than welcome to join the party.
                            john_childs posted this link a while back with some nice freestyle videos.
                            http://www.unicyclist.com/gallery/JapaneseFreestyle
                            Possibly if you can step through the frames you can get some good spin breakdown. They aren't the best quality, but still really inspirational, I love sin02h_1, especially the backwards piruette followed by the sitting gliding spin, WOW. I was also rewatching some of UNICON11 recently.... Irene does some great one-footed front and back spins, WOW again, maybe if I am unlame I will post those videos, unless anyone else has some really good quality freestyle videos, all of mine are painfully grainy...
                            I do have my two favorites from UNICON up, the robot was of course the freestyle champ. If I post anything else this is where it will be:
                            http://web.mit.edu/~zcs/www/unicycle...cle_links.html
                            Hope that helps and look forward to maybe seeing you in Pittsburgh!
                            Zia
                            Why would you need two feet, if you only have one wheel?
                            Comment
                            • #15
                              zia
                              Unfortunately I am busy next Friday or I would show up for the Campus RFools and to meet you. I have the pleasure of supervising a French engineering student who did an internship where I work. That Friday night we are having a going away party. Missing it is NOT an option.
                              I have ridden several times with Mike Carroll and plan on making it to the Pitt gathering sometime.
                              Those Japanese freestyle videos are amazing. They are the first freestyle routines I have ever seen and I loved the fluid, dance style movements.
                              joshp - if you are in Pittsburgh area, post a reply in this thread. I don't check my personal email for this forum very often. I am always interested in riding with others.
                              John F - thanks for the advice. I am appreciative of your experience and willingness to spend time on line to help others learn the sport.
                              Bill
                              Comment
                              Working...
                              X
