Announcement
Collapse
No announcement yet.
Schwinn 20 X 1 3/4 S-7 tire
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Schwinn 20 X 1 3/4 S-7 tire
    I am looking for a new tire for my Schwinn unicycle. It says Unicycle on the
    side and the size is 20 X 1 3/4 with S-7 tubular on it. The LBS is trying to
    sell me a regular 20 X 1 3/4 tire but I want the correct type. The ones at the
    store seem very narrow compared to the tire I am looking for. Any help would be
    appreciated. Please respond via newsgroup. thanks
  • #2
    Re: Schwinn 20 X 1 3/4 S-7 tire
    [color={usenetquotecolor}]> I am looking for a new tire for my Schwinn unicycle. It says Unicycle on the[/color]
    [color={usenetquotecolor}]> side and the size is 20 X 1 3/4 with S-7 tubular on it. The LBS is trying to[/color]
    [color={usenetquotecolor}]> sell me a regular 20 X 1 3/4 tire but I want the correct type. The ones at the[/color]
    [color={usenetquotecolor}]> store seem very narrow compared to the tire I am looking for. Any help would[/color]
    [color={usenetquotecolor}]> be appreciated. Please respond via newsgroup. thanks[/color]
    [color={usenetquotecolor}]>[/color]
    I had the same problem with an ultimate wheel I built. I think it was a S-7, but
    I'm not really sure. I went to a Schwinn dealer and they said that they could
    special order it. I never ended up doing it but I would say your best bet is to
    talk to a Schwinn dealer. You definitely want to get the right tire, schwinn's
    old rim type was purposely made to not fit standard tires.
    Brett Bymaster bymaster@purdue.edu http://shay.ecn.purdue.edu/~bymaster
    Comment
    • #3
      At 01:26 PM 2/24/98 -0800, Jeff Bitner wrote:
      [color={usenetquotecolor}]>I am looking for a new tire for my Schwinn unicycle. It says Unicycle on the[/color]
      [color={usenetquotecolor}]>side and the size is 20 X 1 3/4 with S-7 tubular on it. The LBS is trying to[/color]
      [color={usenetquotecolor}]>sell me a regular 20 X 1 3/4 tire but I want the correct type. The ones at the[/color]
      [color={usenetquotecolor}]>store seem very narrow compared to the tire I am looking for. Any help would be[/color]
      [color={usenetquotecolor}]>appreciated. Please respond via newsgroup. thanks[/color]
      Unfortunately, Those old "Unicycle" tires haven't been made since the early
      1980's. The problem with the Schwinn S-7 rim is it's proprietary size. In other
      words, a 20 x 1.75 tire is not the same as a 20 x 1 3/4 tire. Hey, I didn't make
      this stuff up...
      There are still tires out there that fit the old S-7 rims, but they may be hard
      to find. Try older bike shops, or ones that keep a lot of old inventory. Beware
      the old Schwinn tires. They were long-lasting, but that was because they were
      hard. You could write your name on a gym floor with one.
      Another option is to get a newer rim, allowing you to use all the common BMX
      tires of the present. This isn't the best of solutions either, because then you
      have to find a 28 hole rim, which is usually relegated to lower-end cheap stuff,
      or higher-end racing stuff that's light but not strong.
      Don't worry if your tire says to inflate to 40 lbs on the side (the old Unicycle
      tires said 60). You can still put plenty of air in there, as long as the tire is
      properly seated on the rim.
      John Foss, the Uni-Cyclone unifoss@calweb.com http://www.calweb.com/~unifoss/
      "Never two wheedled"
      Comment
      Working...
      X
