Announcement
Collapse
No announcement yet.
Unicycle pedals /= bike pedals
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Unicycle pedals /= bike pedals
    I've been thinking about the differences between
    unicycle pedals and bike pedals, and I think that
    I've convinced myself that they should be completely
    different.
    A bike (except for a track bike) _can't_ be ridden backwards,
    whereas a unicycle not only can, but it is a common thing
    to go backwards. So this business of threading the pedals
    in one direction or another for a uni is completely bogus.
    In addition, I would love it if the pedals had some sort
    of quick release mechanism so that they could either
    be folded or removed for storing/shipping the uni.
    Why not have the pedals installed on the cranks
    the same way that the cranks are installed on the
    axle -- with a square shank and a nut ? It might
    still be necessary to use a crank-puller, but perhaps
    some other arrangement would work better.
    Perhaps someone else in this group has some
    ideas?
  • #2
    it sounds like a killer suggestion to me
    we'll have to wait for the heavyweights to get back before we'll find out why it cant be done
    the idea of clip-off/fold-up pedals pleases me and the upholstery on the backseat of my car
    Three short Gs and a long E-flat™ - UniHoki
    If I'm Murdered, Don't Execute My Killer.
    harper
    MikeFule Seager BluntRM
    NAMASTE!
    Dave
    Comment
    • #3
      Re: Unicycle pedals /= bike pedals
      Is that not complicating things rather than simplifying them? The you'll need a spanner and a crank puller rather than just a spanner.
      As things are pedals are fairly simple to remove, they just requier a bit of brute force occassionally. Maybe just a longer spanner (or welding an extension onto an existing one) may be all that you need.
      The quick release idea sounds okay, though strength/moveability of interface might be an issue (moveability issue similar to creaky Profile crankset).
      Maybe something like this (hope it attaches okay). The pedal spindle end would be square section or maybe splined. Harper, apologies for incorrect depiction of threaded sections, it's all I could do in MS Paint and 10 minutes...
      Time for me to think up a new sig.
      Ermmm... uh... hmmm...
      You know that really witty and original thing you heard the other day? Well imagine that I said it and it's now written here.
      Comment
      • #4
        originally posted by hbaker1@pipeline.com: In addition, I would love it if the pedals had some sort of quick release mechanism so that they could either be folded or removed for storing/shipping the uni.
        Well, until you've completely convinced yourself about the pedal question, here's an answer to half of your wish:
        http://store2.yimg.com/I/strida_1672_678277
        Here's the link for the vendor:
        http://store.yahoo.com/strida/2-u151.html
        I just found this one... could these be THE ANSWER ???
        http://www.bikefriday.com/catalogpic...tem=112&page=8
        http://www.unicyclist.com/gallery/al...y_eye_ball.gif am the http://www.unicyclist.com/gallery/al...lbun00/aac.gif in the Ointment.
        Comment
        • #5
          Wow. . . chromed too. . .
          Comment
          • #6
            I'd thought about a different way of attaching pedals, too, then came to the conclusion there would be no obvious advantage.
            Using a system similar to the way cranks are attached to the axle would be no good: I've had cranks work loose at least as often as I've had pedals work loose, and using a crank puller is more complex than using a pedal spanner.
            On the whole, if it ain't broke, don't fix it.
            But what about the argument on right and left hand threads? Yes, unicycles go backwards quite often, whereas bicycles don't. However:
            1) I'm sure that most unicycles go forwards more than they go backwards, by a very wide margin indeed, so the left hand/right hand effect is still there.
            2) As things stand, you can go out and buy any of dozens of designs of pedals from any bicycle shop. If your uni had two right hand threads, you'd either have a limited selection, or you'd have to buy two pairs and throw the two lefts away (or vice versa). Few obvious advantages here.
            And as for the folding pedals... imagine the hilarity that could ensue when freemounting.
            My first novel, Bridge of Otherwhere, Michael Wilkinson, on Kindle. A tale of subtle magic, mystery, friendship and love. Tinyurl.com/Bridge-of-Otherwhere For US$ page: TinyURL.com/OtherwhereBridge
            Comment
            • #7
              perhaps a different approach to the problem,
              why not keep the cranks the same and think about how the pedals could be made to stay on better.
              what about a set of pedals with extra long tapered sections that can have an lock nut on the end.
              or you could drill holes in the axles in your pedals, thread them internaly and secure them on with a bolt like splined cranks do. this wouldn't be too hard to do, you'd just need a bench drill and a tap and die set.
              this would sacrifice some axle strength strength but then i've lost more pedals to stripped threads than snaped axles.(bent axles are annother story though)
              profile racing would probably make you a set if you paid them enough monney.
              then agian if i was going to get profile to build me a set i'd have them splined with a matching set of custom cranks.
              evilewan.
              see the outdated but still usefull rec.sport.unicycling maintainance FAQ @ http://evilewan.unicyclist.com/
              Comment
              • #8
                I'm not sure what the actual problem is. I go backwards a lot these days and have no problems with the pedals staying on. If I want to remove them it's easy with a simple 15mm wrench. Putting them back on needs the same wrench and a little blue loctite. No problem and takes a minute or two max to do the on or off part.
                Weep in the dojo... laugh on the battlefield.
                -- Dave Stockton
                Comment
                • #9
                  there apear to be two problems that require two different solutions or one very clever one:
                  problem 1: some uni riders want pedals that come off easily in a way that doesnt requre tools.
                  problem 2: trials riders (like me) don't want their pedals to loosen up when doing pedal grabs.
                  i recon my solution to problem 2 is workable, i've got a spare pair of pedals. i'm going to drill holes into thir axles and then thread the holes so i can bolt them on to the cranks and see if it works.
                  evilewan.
                  Comment
                  • #10
                    Have you tried some Red LocTite before you drill holes into your pedals. That stuff is ment to be perminate, I just use the blue stuff because it holds good enough for me, but with a bit (alot sometimes) of force you can still remove them and swap out parts. Just a thought
                    Chex
                    No one said it was gonna be easy and I'm not afraid to try, with the odds stacked up against me I will have to fight, One Life One Wheel got to do it right. H2O
                    -------MUNI MILITIA -------
                    One Wheeled Death Squad
                    Comment
                    • #11
                      Backwards technology.
                      The current design of pedal thread direction is backwards anyway. I have often wondered why everybody follows this convention. If a pedal bearing is sticking enough to turn the pedal axle, your pedal will only tighten itself if you are pedaling backwards. When you thread a pedal onto a bicycle by starting the thread and then spinning the crankarm, which way do you spin the crank to tighten the pedal? That's right. (Try it.) So ride backwards all you want. Forward pedaling is the problem. Red Locktite is the fix for most people. And maybe a little oil on the bearings every now and then.
                      Jeff Baker
                      jeff@unibiker.com
                      MAKE IT A GREAT DAY!!! > > > > Unibiker's Photo Gallery
                      Comment
                      • #12
                        This question comes up periodically (I asked it myself once, some time ago).
                        Actually it's not the friction of the pedal bearings that causes the pedal to
                        unscrew, but rather an entirely different force the official name of which I do
                        not know offhand (precession?). It's a bit counterintuitive but it can be
                        demonstrated. Form a small circle with your thumb and forefinger, tight enough
                        to loosely grasp a pencil or other similarly-shaped object. Your hand is the
                        end of the crank-arm, and the pencil is the pedal axle. Very lightly hold the
                        free end of the pencil -just pushing it with one finger is best - and move it
                        so that it traces a circle in the air. You will see the body of the pencil
                        rotate in the direction opposite to the direction in which you are moving the
                        end. This is what happens to the pedal axle as you ride. As you ride forward,
                        the force applied to the axle of the right pedal pushes its end in a
                        counter-clockwise circle relative to the crank-arm, so it tends to tighten
                        clockwise. It didn't make sense to me either until I did the pencil thing,
                        thanks to someone on this group a year or two ago.
                        - Joe
                        If Teddy Grahams crackers
                        were shaped like goats instead of bears,
                        would they be Billy Grahams?
                        Comment
                        • #13
                          Re: Backwards technology.
                          There is nothing backwards about it. See the following thread "Why is the left pedal left-hand threaded?"
                          <http://www.unicyclist.com/forums/sho...threadid=18867>
                          If your unicycle is having problems with a pedal coming loose it is probably due to cheap pedals in cheap cranks.
                          The threads on cheap pedals are rolled on (they are not cut or machined) and the tolerances are not held very close. The threads can end up undersized. The threads in cheap cranks also can suffer from poor workmanship. A combination of poor threads on the pedal and poor threads on the crank mean you will never be able to keep that pedal tight.
                          Higher quality pedals have machined threads that are held to higher tolerances.
                          Put quality pedals on quality cranks and you will not have problems with cranks coming loose.
                          john_childs (att) hotmail (dott) com
                          Team Never Wash Your Muni
                          My Gallery :: Unicycling Bookmark List :: World Clock
                          Comment
                          • #14
                            >> *The current design of pedal thread direction is backwards anyway. *
                            ><http://tinyurl.com/ys0>
                            >john_childs
                            There it is.
                            Comment
                            • #15
                              RE: Unicycle pedals /= bike pedals
                              > but it can be demonstrated.
                              It can be demonstrated even easier using the "scientific" method. Turn your
                              unicycle's seat around and do some hard riding. Just remember to bring your
                              wrench with you because you'll need it.
                              JF
                              Comment
                              Working...
                              X
