Announcement
Collapse
No announcement yet.
Advice needed for beginner.
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Advice needed for beginner.
    Myself and a friend have been learning to uni for the past two weeks
    now (as some of you may know from my previous posts). We started by
    using a railing for support while we got the feel of being on the uni
    and then we progressed to riding along with one hand on the other
    person's shoulder, sort of like having 'training wheels'. This all
    went along very well and so we decided to follow Dancey's advice and
    'launch into the abyss'. I found with an hour or so a day of practice
    at the tennis court, in the underground parkade and at the local
    elementary school playground I have gotten to the point where I can
    ride about a block or two at a go. Today I did some block long laps
    of a big empty parking lot at a nearby college.
    Here's the problem though: my friend who has been practicing along
    with me is hopelessly stuck at the stage of trying to ride on her own.
    She gets one or two revolutions and then just stops dead and steps
    off the uni. So we went back to some assisted starts for a while to
    build skill and confidence and then the next day she was able to do a
    few 8 foot runs. However today she is back to just going one or two
    revolutions and stepping off. She sweated away at the same
    'start,pedal once or twice and step off' for over an hour with no runs
    at all!
    This process has been very frustrating for her and on more than one
    occassion anger hung heavy in the air.
    I am such a newbie myself that, even though I have combed the archives
    for tips, I just don't know what to suggest at this point.
    In fact I'm not sure that it isn't too late; could be my pal is on the
    verge of giving up totally. ;-(
    I have tried to get her to lean forward to promote the momentum needed
    for the uni to roll and when I walk her through this technique it
    seems to work but she just can't get going on her own.
    Any advice would be greatly appreciated.
    Thanks,
    Erin
  • #2
    Weight on the seat. Focus at a distance. Ride until you fall off, don't chicken out and step off.
    -Greg Harper
    Nipples...do you ever have enough?
    Change is good. Bills are better.
    Comment
    • #3
      Re: Advice needed for beginner.
      Erin,
      Having just learned to Uni myself and assisted my 11 year old daughter
      with learning the Uni, I think I may be able to offer some advice... try
      spotting her.
      It sounds like your friend may have the skills but is afraid to hurt
      herself, which is totally understandable. My daughter was in the same
      situation. I would spot your friend for a couple days while she builds
      up her confidence.
      With my daughter, I would help her mount, get her balance and then let
      her hold my hand for a few pedal strokes until she was moving, then I
      would just hold out my hand (palm face up) so she could touch it
      lightly- but she knew I was always there for her (important). I would
      simply remind her of the basics- keep your head up, look straight ahead,
      smooth pedal strokes. Then when she had her 'Zen moments' I would offer
      to let her go solo, if she said yes I would stop walking and let her go.
      Soon she was going all the way down the street, then around the block
      and now we can 'lollipop' around a couple of miles together no
      problem.
      And if all else fails, have her raise the seat.
      Jason
      Comment
      • #4
        Sounds like the main thing is lack of confidence, possibly coupled with the effect of getting into a negative feedback loop. Improve the odds by doing some of the following:
        1) Check the seat height. Get your friend to sit on the seat with her foot on the pedal at the bottom of its travel, heel on the pedal (NOT instep or ball of foot). The leg should be comfortably straight, but the knee should not be locked. That is the perfect height for a bicycle seat. Now lower it half an inch or so (couple of centimetres) and that should be the ideal height for a unicycle seat.
        2) Concentrate on weight on the seat, not on the pedals.
        3) Look at least 30 feet (10 metres) into the distance. DON'T look at the ground immediately in front.
        4) Many people find it encouraging to count the pedal strokes, and keep track of their progress. A typical learning curve will go 1,1,1,1,1,1,1,1,2,1,1,2,1,2,1,3,1,1,2,1,3,3,4,2,1,5,3,2,3,2,4,6,10,3,15. ..
        5) Aim for a smooth circular pedaling stroke. Some riders try to be in a state of perfect balance at all times, so they try to stop and regain balance after each pedal stroke. This more than doubles the difficulty of the task.
        Your friend should aim for 'dynamic balance' which means that the unicycle is only balanced as long as it stays moving. A good illustration of this is to balance a broom (or similar) on your finger, then try to walk a few metres. It's easier if you can let the broom start to fall, then try to keep up with it, rather than trying to have the broom perfectly balanced at all times.
        6) Try to find a practice area with a slight downhill on it.
        7) Break the spell by trying something different. Mount in a different place on the wall, or try to start with the other foot leading. Get your friend to help you with a skill you're learning. Once you get into a rut with the same mistake happening time and again, all you are doing is burning the mistake into your muscle memory. Practising whilst angry with yourself only makes things worse.
        8) Experiment with things like trying to ride round and round a post, holding onto it, or riding alongside a wall, trailing your hand along the wall (wear gloves).
        9) Experiment with freemounting now and again. Sometimes trying a difficult skill makes the easier skill come more quickly.
        10) Don't make your friend feel stupid or inadequate. Even gentle teasing and sarcasm are likely to be counterproductive.
        Good luck.
        My first novel, Bridge of Otherwhere, Michael Wilkinson, on Kindle. A tale of subtle magic, mystery, friendship and love. Tinyurl.com/Bridge-of-Otherwhere For US$ page: TinyURL.com/OtherwhereBridge
        Comment
        • #5
          Mike, that was a very nice post! Great, really!
          http://www.unicyclist.com/gallery/al...y_eye_ball.gif am the http://www.unicyclist.com/gallery/al...lbun00/aac.gif in the Ointment.
          Comment
          • #6
            Im just learning too and what i do is to make sure im fully padded up , wrists, knees, shins, elbows and a helmet. this instantly gives me confidence to keep pedalling i also made a huge breakthru when i used the balls of my feet on the pedals i seemed to have more control.
            good luck
            Comment
            • #7
              Lowering the seat height an inch or even two from what my nephew picked himself helped an awful lot in keeping him on the uni. His hips tended to rock at his seat height, which really seems to destabilize the entire process. Better too low than too high.
              Weep in the dojo... laugh on the battlefield.
              -- Dave Stockton
              Comment
              • #8
                >at all!
                What she is going through is a completely typical learning process. That
                "start,pedal once or twice and step off" thing is programming her reflexes, a
                little bit at a time. She WILL get it if she keeps trying. The only question is
                whether she has the will to keep trying. I hurled myself back and forth across
                the floor of my apartment for two weeks before I could get from one wall to the
                other without falling down. The dark secret of unicycling, what we don't want
                the public to know, is that anyone with an average sense of balance can ride
                the thing. The body just has to develop a completely new set of reflexes for
                its sense of balance to use, to handle this very peculiar new balancing
                challenge that's being thrown at it. This takes varying lengths of time for
                different people, and most people who try it decide too soon that it's
                impossible and abandon it. Seeing someone else picking it up faster than she is
                is no doubt adding to her discouragement; she needs to know that the time that
                she's taking is NOT unusual. I am SURE that she is very close to the edge now;
                whether her increasing ability will win or lose the race with her frustration
                is the question.
                It might be easier if she has two solid cling-to structures, walls or poles or
                something a few yards apart, that she can ride one to the other, instead of
                trying to ride off into the wide open. Having a defined short distance with
                something to grab onto at the other end is a great help. When she can wobble
                between these two things, find two other things slightly farther apart.
                Taking a day off from it now and then is likely to help.
                - Joe
                If Teddy Grahams crackers
                were shaped like goats instead of bears,
                would they be Billy Grahams?
                Comment
                • #9
                  On Sun, 14 Jul 2002 12:04:16 -0500, sendhair
                  I thought exactly the same. I've always assumed that the "Roland Hope
                  School of Unicycling" sig line was a joke, but this list of very
                  useful and to-the-point advise would be worthy of any School of
                  Unicycling. Mikefule, what is it with that sig line?
                  I could add one thing from own experience, corroborating Jason's
                  advice. When I was learning to ride 1.5 years ago, I was kind of stuck
                  to riding along a wall rack (in a gym). I could ride for 10 meters
                  along the rack but at most 1 revolution when in the open. I then had a
                  helper who was strong enough to trust as a support. He held my hand
                  firmly until I had some confidence, then he gradually let go. And
                  there I went on my own. If I ever had a breakthrough moment in
                  unicycling, this was it!
                  The seat height / weight on seat debate is undecided yet, with
                  conflicting advice so far. While weight on seat definitely improves
                  riding once you have some ability, I am personally not convinced that
                  it should be emphasised in the early learning stage. But others hammer
                  on it. Also, I think that having the seat too low, even by a couple of
                  inches, was not very detrimental to my learning.
                  Klaas Bil
                  Comment
                  • #10
                    Klaas Bil
                    Comment
                    • #11
                      Klaas Bil
                      Comment
                      • #12
                        Hey Erin,
                        You mentioned your friend going back to "assisted starts" for a while, and maybe what I'm about to mention is just that, but... when I was at the point of "launching into the abyss" (I had the Dancey book aswell), I found that it became a lot easier when I was already moving along steadily before letting go of a wall/rail. I did this by finding an open area with a building jutting out into it, and then riding along the edge of the building with my hand against the wall for stability for a couple of pedals. Then once I was in the open, I found I had more success because I was already balanced. I think this definately reduced the time it took me to get comfortable with riding unassisted.
                        Hope this makes sense!
                        Trenton
                        Comment
                        • #13
                          -----BEGIN PGP SIGNED MESSAGE-----
                          Hash: SHA1
                          I'll weigh in on the debate. Part of the idea of having your weight on the
                          seat is to make riding more stable with less wheel wobble. It also makes the
                          rider relax their legs some so they have more control. The trick, of course,
                          is for the learner to get comfortable enough to rest their weight on the
                          seat, and that depends on the means of instruction. So perhaps it is a goal
                          in the learning process rather than up-front advice like having good posture
                          or not looking down.
                          The big problem with having the seat too low is that your legs get tired
                          sooner. Most beginning riders are developing new leg muscles along with the
                          skill of unicycling and anything to cut down on the fatigue is helpful. In
                          the earlier post when the persons hips were rocking, though, the seat was too
                          high for any purpose.
                          Beirne
                          > Klaas Bil
                          > ________________________________________________________________________ ___
                          > rec.sport.unicycling mailing list - www.unicycling.org/mailman/listinfo/rsu
                          -----BEGIN PGP SIGNATURE-----
                          Version: GnuPG v1.0.6 (GNU/Linux)
                          Comment: For info see http://www.gnupg.org
                          iD8DBQE9MhIAZ0K5gJuiS1QRAusuAJ4nXXG2IL6undVzipPGy03hP/CNhwCfYejK
                          ImsXIwzyT80orYXF3FMr+SU=
                          =4W+0
                          -----END PGP SIGNATURE-----
                          Comment
                          • #14
                            For days 3 and 4 of my learning process, I used a pair of North-Western wood drivers upside down as ski poles. (these were very cheap golf clubs.) This gave me the sense of unicycling unsupported with a small degree of safety. It also helped greatly with learning how to free-mount. Days 5 and 6 were spent almost exclusively with learning how to free-mount. Once every 15 or 20 min I would use the golf clubs so that I could ride a bit. Then it was back to having the uni shoot out from under me over and over. It took me about 20 hours of practice before I could ride even 20 yards. After that my progress has accelerated.
                            Let's go over this again. I fell which direction?
                            Comment
                            • #15
                              "Wow, with such encouraging words of advice, I'm truely inspired to
                              keep at it!"
                              This is what my friend said after she had read your many posts
                              offering practical tips and encouragement. She was quite buoyed up by
                              so many caring unicyclists taking the time to offer suggestions.
                              Tonight we approached things with a new perspective. The evening was
                              cool, we were in an open area with not many people around and we vowed
                              that we would have some fun with this learning to uni and stop if
                              things got too frustrating. Then we put a lot of your suggestions to
                              work.
                              We started off with some assisted rides, using first a wall and then
                              me as the helper. Then took a break. Then more assisted rides and
                              gradually the assists were just at the start, after a couple of pedal
                              revolutions my friend headed along on her own. She kept focused on a
                              spot a short distance ahead and just tryed to relax and pedal
                              smoothly. In this method she achieved quite a few 10 foot rides and
                              one 14 foot ride.
                              Though she can't quite do an unassisted start yet she did feel like
                              she was making some progress.
                              We did vary the locations in the area that we were practicing and took
                              frequent breaks. All in all it was a lot more fun for both of us and
                              most importantly confidence building for my friend.
                              Again, thanks for all your help.
                              Erin
                              Comment
                              Working...
                              X
