Announcement
Collapse
No announcement yet.
Road tire for Muni rim - suggestions please
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Road tire for Muni rim - suggestions please
  • #2
    I use a 3.8" Veetire speedster on my 26" geared Huni-rex, it is a road only tire in a pothole dampener width
    Comment
    • #3
      I use a Continental Double Fighter II, 27.5 x 2.00, on the same unicycle.
      Comment
      • #4
        Comment
        • #5
          The Continental Double Fighter rolls much easier and is more agile.
          Click image for larger version
          Comment
          • #6
            In my experience a road tire that is at least as wide as the outer dimension of the rim works without issue.
            As long as your rim isn't wider than 50mm a 2" tire should work fine.
            Just be careful around curbs etc as wide mountain rims will increase your risk of pinch-flats with road tires as they result in less vertical sidewall than an appropriately skinny road rim.
            Comment
            • #7
              Comment
              • #8
                Oh and of course, remember that if you are using a unicycle that was intended for Muni as a road machine, consider your crank length. You will almost certainly want shorter ones for road use. Personally I love the Nimbus VCX+, 3-holed cranks. For road riding in the non-snowy months (and even in light snow), I have them in the 100mm position.
                Comment
                • #9
                  Thanks for all the extra info.
                  I'm currently running 110-136 cranks on the 27.5" but have never gone below 136 mm on this size. (On the 24" I run 125-145 cranks).
                  Once I have a road tire (and gotten used to it) I'll try to work my way down on crank length.
                  Comment
                  Working...
                  X
