Announcement
Collapse
No announcement yet.
Bearing Spacers ?
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Bearing Spacers ?
    Hi can anyone help me ? I am replacing the bearings on my 36" Oracle and i am unsure if there is supposed to be a spacer on both sides of the bearing or just on the crank side?
    Thanks in advance
    Phil
    24"Nimbus
    27.5 KH
    36" Nimbus Oracle
  • #2
    It may vary depending exactly what axle. I'd replace what was there originally.
    This is what was on my Nimbus 36er with an aluminum hub:
    Comment
    • #3
      Bearing spacers
      Hi Jim thanks for the reply i have a different hub than that, but i called Roger at UDC and he said that my hub only has a Spacer on the crank side.
      Regards Phil
      24"Nimbus
      27.5 KH
      36" Nimbus Oracle
      Comment
      • #4
        Do a dry fit and measure before installing the wheel. For a 36" Oracle the bearings should be 125mm centre to centre.
        Unicycling is the fountain of youth.
        Comment
        Working...
        X
