Announcement
Collapse
No announcement yet.
Aluminium vs steel frames
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Aluminium vs steel frames
    Hi again guys. Sorry for the questions. Does anyone have preference over aluminium or steel for the frame. All my usual bikes (as in two wheel not one) have been CrMo steel, since I “trust” steel more than aluminium, and would, if given the option choose a CrMo steel again. Does anyone have any insights or comments ? Thanks.
  • #2
    Years ago, when I was shopping for a used mountain bike, I was faced with the same decision. I read that steel flexes more. Given the straight shape of a unicycle frame, I'm guessing that effect is minimal.
    I have a Drak steel frame on my 29" and a Nimbus Muni steel frame on my G26. My other three unicycles have aluminum frames. Extra weight adds a feeling of sluggishness. So, everything else being equal, I prefer the lighter aluminum frames. Some riders have mentioned that weight saving is best done by reducing the rotating mass of the wheel. True, but the weight of the frame also adds some inertia.
    I haven't had any problems with my aluminum frames (Equinox 20", Impact 24" w. 32mm bearings, Oracle 26"). The only situation where I imagine steel would outperform aluminum is in an unusual UPD where the rider steps onto the frame. Never happened to me. Or maybe you get pissed off easily and like to throw your unicycle a lot.
    Comment
    • #3
      The difference between a steel nimbus 29er frame and a KH aluminum frame is 50 grams (less than 2 ounces). I doubt a rider could tell the difference while on the trail. There is no doubt that they feel different, but that is not a factor of weight. One's choice in a tire makes a much bigger impact. For me it all boils down to $ I'm not going to pay a hundred bucks more for 2 ounces.
      Comment
      • #4
        The main difference I've noticed with my 'expensive' aluminium KH frame compared to my 'cheap' Qu-Ax steel one is stiffness (I put quotes round them as neither of the frames are particularly expensive compared to a b*ke frame!). It actually is noticable, a lot more than the weight difference - this might contribute to the 'sluggish' feel as well especially if you push a lot of power down.
        Some people prefer the less stiff feel of steel but I really like a super stiff setup for road. If you're the sort of person to jack your tyre pressure right up to the highest number written on the side you might prefer it too, otherwise a steel frame will serve you awesomely. My steel 36er frame flexes a lot more than the steel 29er as well, so again wheel size might play a factor into your decision.
        “It is well known that a vital ingredient of success is not knowing that what you're attempting can't be done. A person ignorant of the possibility of failure can be a half-brick in the path of the bicycle of history.”
        Comment
        • #5
          Originally posted by Piece Maker View Post
          The main difference I've noticed with my 'expensive' aluminium KH frame compared to my 'cheap' Qu-Ax steel one is stiffness.
          I have not been able to do an "apples to apples" comparison between steel and aluminum frames, due to all the other differences in setup on my unicycles. I am curious where you think the most significant form of flex is happening on the steel frame, and how much motion we are talking about.
          I do have one annoying issue with my Drak (steel) frame that is not present on my other unicycles: I'm having trouble keeping the seat post from moving from side to side. I use a short handlebar setup, and with all the pushing and pulling on them, the interface between the frame and seat post doesn't seem as solid as on the aluminum frames. This issue could be attributable to other factors. Anyone else have that issue with a steel frame?
          Comment
          • #6
            One other thing to note, and this might be totally anecdotal, I've seen a few posts about aluminum frames failing (cracking at welds). I don't recall any posts about a steel frame failing (other than the small diameter tubing oregon and night rider style frame).
            Comment
            • #7
              On the 36er (steel) it's most noticable in a twisting type motion, so it's like the fork legs are going back and forth round each other. On the steel 29er vs. ali 29er... I'm not so sure. It just sort of feels tighter and more solid, like there's less overall squish to the frame (So... downwards or for/backward maybe?)
              I agree that it's too hard to make a real apples to apples comparison though. My steelies are both bottom-budget Qu-Axes with stock wheels while my aluminium one is a KH with Nimbus D2 or carbon rim depending what I'm riding, so it's completely possible that the rims make it feel all stiffened up as well. But to me the flex on the steel frames is between my butt and my feet, rather than between my feet and the ground. It's subtle but it's definitely there, whereas on the aluminium one there's seemingly no give in it whatsoever.
              Comment
              • #8
                For a typical unicycle frame, the major sresses are when you pedal hard, especially when pulling up on the seat/handle. Your legs put a high amount of twisting torque into the frame. I learned this the hard way when my old carbon fiber frame "failed" out on a trail, miles from the car. This was a 1999 Roger Davies frame, with carbon tubing into aluminum lugs, and there wasn't quite enough adhesive down around the bearing holders. The torquing force broke the connection, the bearing holder and/or fork tube vs. crown twisted a little, and the wheel stuck against the frame. I could not for the life of me get it to twist the other way, because it was still really tight.
                So I had to carry the uni up and back to the car, take it apart and mail the frame back to England. But it was so light, all of that was pretty easy. He fixed it with some aluminum pins, to keep it from turning. and it never had a problem after that.
                From that experience I learned from that experience how much twisting force goes through a uni frame. If you ride uphill a lot, race, or do other things involving hard changes in speed, the stiffness of your frame can be a factor in relation to that torquing effect. Stiffer will equal higher performance.
                This can be especially troublesome on chrome plated frames, where there's a lot less friction. Double-bolt seat clamp recommended there. Also you can try "roughing up" your seatpost with a file or similar to create some texture on it.
                John Foss
                www.unicycling.com
                "Who is going to argue with a mom who can ride a unicycle?" -- Forums member "HiMo"
                Comment
                • #9
                  Steel vs aluminum
                  I don't have enough unicycle experience to help. However when after years of riding a steel frame road bicycle, I tried an aluminum frame road bicycle, which happened to have a steel fork. The forks were very similiar, and the primary difference was the frames. I found that I became fatigued quicker on the aluminum frame and had trouble keeping my normal steel frame pace. This was doing weekly group rides with a local club, so I think it was fair of me to judge my ability to keep up with the same riders week after week. What I eventually learned was that aluminum frames are nice and light, but often much stiffer than a steel frame. The aluminum frame doesn't flex and give as much of a soft ride over small road ripple type bumps. It does however, flex great over the bigger obstacles absorbing those impacts. On my road bike, I tryed a carbon fiber fork in place of the steel fork, which for me only provided a very minor improvement. I then tryed a Rock-Shox suspension road fork, and wow! It was a whole new game. The aluminum bike that was beating me up was now as comfortable as any road bike I'd ever ridden. The suspension fork made up for the stiffness of the aluminum frame and I could keep up with the group again.
                  So while not dirrectly comparable, I hope the experience helps. On a unicycle it probably depends more on the type of riding surfaces. Lighter is generally always better. But if you ride in an area with a lot of small high frequency ripple type bumps, I would expect aluminum to be a little tougher on you than steel. But aluminum might be better if you take a lot of hops and big drops. And not to sound potentially contradictory, but I have been very comfortable on an aluminum framed road unicycle on smooth roads.
                  Comment
                  • #10
                    One advantage of aluminium is the resistance to corrosion. Doesn't matter so much if the paint gets scratched.
                    I can't really compare the flex. My 20 and 24 inch unis are steel framed but that is probably too small to notice any flex. Middle sizes are all aluminium and seem quite rigid.
                    The 36 is a Triton titanium. It is built of quite large section tubing and I have never noticed any flex in it. Corrosion resistance doesn't come better in any other engineering metal.
                    Triton 36" + 29" | KH 29" | KH 26" | KH 27.5" Muni | Nimbus eSport Race 24" | Torker LX 24" | Qu-Ax Luxus 20" | Qu-Ax Profi 20" | KH / Impact 19" hybrid
                    Comment
                    • #11
                      The way a unicycle frame is pointed in almost a straight line from contact patch to rider, it can barely act as a suspension, in the way a bike frame/fork can. Where you feel differences in frame stiffness, (as others pointed out) is riding uphill, and other times where you pull on the seat a lot. For riding uphill, as long as the wheel doesn't touch the frame, and the diskbrake doesn't rub, I don't care, it's just getting used to any particular setup. For hops I prefer a stiffer frame, as I find it confidence inspiring, but it's honestly not a priority.
                      If you ride aluminium frames hard, they will fail. My Impact gravity frame developed a crack after 7 years of hops over 75 cm, and a lot of Trials/Street/Flat riding. Outside of those disciplines, frame failures are very rare, as the forces are a lot lower. It's also probably not a really good evidence either, as virtually all the top riders ride aluminum frames, and they are the ones most likely to break parts.
                      In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -Douglas Adams.
                      Comment
                      • #12
                        Another factor in this discussion apple/pear comparison is shape (construction) of the frame...
                        Next 1/1/2020 I will be unicycling 25 year exactly. Some of my history of unicycles:
                        For 15 year I drove steel (Semcycle Pro and XL)
                        For few weeks I tried alloy (KoxxOne, Kris Holm, Impact)
                        For 10 year I drove titanium (Triton, 4x Nimbus, and my "Gino" frame).
                        I would dare the challange to tell blindfolded what kind of frame I ride, but for sure I can tell blindfolded when I ride a Semcycle Pro, which was designed to be flexible.
                        This kind of flexibility adds to riding-comfort, and makes riding circles more smooth.
                        A too rigid frame however, isn't comfortable. Maybe for launching a high-number-of-rev unispin, but not while being seated.
                        If you're flexible you bend,
                        If you're not flexible you crack.
                        ~karate kid's master.
                        Originally posted by johnfoss View Post
                        For a typical unicycle frame, the major stresses are when you pedal hard, especially when pulling up on the seat/handle. Your legs put a high amount of twisting torque into the frame. I learned this the hard way when my old carbon fiber frame "failed" ... 8< ... with carbon tubing into aluminum lugs, and there wasn't quite enough adhesive down around the bearing holders.
                        That's one force example, but simply doing corners, with a large wheel; imagine to hold that together with your muscle-power, and probably you suddenly estimate these forces a lot stronger.
                        Then think of a doing pairs and a spin, or a flague. A 29'er going fast trough a slight bending road.
                        Early '90-ies track bicyclist Urs Freuler couldn't sprint anymore when you put him on alu frames. The lack resistance (I don't call it stiffness) was transported by his muscles and nerves, and some neurologic reflex made it impossible for him to apply force. I think a Austrian university researched it, and in the meanwhile he returned to steel, returning to win 6-days track races again.
                        Where titanium doesn't need any anodizing for that.
                        I don't know the exact numbers -correct me if I'm wrong- but I think:
                        - alloy is more flexible than steel, but less good in returning to it shape.
                        - titanium is even more flexible than steel and alloy, but very rapid in going back, where the large wheel is adding up...
                        So for it's flexibility and strength I used it for my own frame, which has thin double tubing with the (successful) intention to make it as flexible and responsive like a spring - and strong enough for the extremer forces in pair unicycling.
                        Beside that I still use the Nimbus Ti. It's so durable; people still ask wether it's new (while in reality being about 10 years old). I wont be surprised the moment those will be reproduced. Or maybe they were too good.
                        unicycle.show
                        unicycle.blog
                        unicycle.builders
                        +1 866 UNI-CYCL
                        Comment
                        • #13
                          Not if you use a stainless steel tubeset.
                          Adventure Unicyclist
                          Alps 2 Ocean
                          Unistan: The Uzbekistan Unicycle Tour
                          Induni: The India Unicycle Tour
                          Monguni: The Mongolia Unicycle Tour
                          Comment
                          • #14
                            I think I see stainless steel with maybe a copper layer and likely nickel layer and clearly chrome plating layer.
                            Not sure if you consider 25CrMo4 a "stainless steel", but I've seen a few ending up having heavy corrosion. With different causes, but probably all initially started at the chrome layer, or directly underneath.
                            You still better keep it clean and dry.
                            unicycle.show
                            unicycle.blog
                            unicycle.builders
                            +1 866 UNI-CYCL
                            Comment
                            • #15
                              That's a polished stainless steel KVA MS3 tubeset, no chrome at all.
                              Alps 2 Ocean
                              Comment
                              Working...
                              X
