Announcement
Collapse
No announcement yet.
Narrow winter tyre on 24" Muni rim?
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Narrow winter tyre on 24" Muni rim?
    Would a 47-507 tyre fit on Nimbus Dominator 2, 24" x 42mm rim? I'd like to get a studded winter tyre for a Nimbus MUni 24", and the Schwalbe Marathon Winter 47-507 seems to be the most available 24" option where I live.
  • #2
    It will fit, but won't be ideal.
    You will have to run quite high pressure to avoid pinch-flats or sidewall damage. I have no idea what your winter conditions are like but you might be better off DIY studding a wider tire with a good cold weather rubber compound.
    Running a pizza cutter wheel in the winter can be a ton of fun in the right conditions. It's a nightmare in others.
    Comment
    • #3
      Thank you for your heads-up about the pressure! As far as I understand, with high pressure these tyres will mostly ride on the center, where there are no studs. That's a feature to adapt the tyres for ice free days. I might go for a DIY solution as you suggested.
      Comment
      Working...
      X
