Announcement
Collapse
No announcement yet.
Seat post cut - a stupid mistake
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Seat post cut - a stupid mistake
    Hello all
    I made a rather basic error and had my LBS cut my new seatpost - and I based it on the letters on KHs all in one seatpost. Of course the post I was basing this off has the letters printed lower down then in the post being cut!
    Yep really daft and I am kicking myself now as I shouldnt have been in such a rush.
    Anyway, it means that about 2 of post are in the frames stem (and fully clamped past the grove at the top) - however this is in a 36er with the saddle all the way down - at the lowest possible setting.
    My question is - will this be safe to ride like this? Naturally Id prefer it to have one more inch of seatpost in the frame - but I cannot face buying another post if I can help it. Im presuming the forces on this use case are less given that the post in all the way down - but I wanted to check here. I do use a touring bar so I guess that may add it the strains but I cannot really see that a post 1 inch longer would improve in the set ups ridgidity.
    All advice gratefully received :-)
    The wheel is come full circle, I am here.
  • #2
    Im sure Ive got just 2 left of seat post in some of my Munis (when changing the cranks length/hole setting in the KH 127/150 cranks) and Ive never had a problem so far...
    Comment
    • #3
      2" sounds okay. I think the minimum insertion printed on most seat posts is closer to 3". I have been using less than the minimum insertion on my 26" Oracle. The seat post for the Shadow handle I use came in one size, and it's barely long enough. I push and pull hard on my handlebars, and I have not had a problem with the interface between the neck and the seat post. Makes me a little bit nervous, however. Make sure your seat post clamp is tight enough and attached correctly (not sliding up the seat post).
      Comment
      • #4
        Thanks so much for your replies
        Yep makes sense and I think I was overthinking this a tad too much. With this 36er set up and 2 of post well clamped in it must be fine.
        Cheers for reassuring an overworrying unicyclist
        Felix
        Comment
        • #5
          2" is OK.
          I guess we've all made that mistake in one form or another. I once cut my seat post to the minimum length I could get away with, to save weight, then a few weeks later, put shorter cranks on, raised the seat and...
          My first novel, Bridge of Otherwhere, Michael Wilkinson, on Kindle. A tale of subtle magic, mystery, friendship and love. Tinyurl.com/Bridge-of-Otherwhere For US$ page: TinyURL.com/OtherwhereBridge
          Comment
          • #6
            I've previously read that you should always have double the diameter of the seatpost within the frame. Therefore two inches, or just over.
            "Ride It Baby!"
            Comment
            • #7
              In the skills progression of many unicyclists, a few things happen to raise the seat higher. They learn to mount with the pedals in a more parallel position, making it easier to clear a higher seat, they incorporate the up/down motion of the hips into riding, they may progress to shorter cranks and they may adjust their foot positions slightly closer to the toe. I would prefer if the manufacturers made the necks on some frames a little bit longer, so there is more of a range of adjustment without having to cut -- or buy a new seat post.
              Comment
              • #8
                Making the frames taller would reduce the potential for shorter riders to fit on larger unicycles.
                "Ride It Baby!"
                Comment
                Working...
                X
