Announcement
Collapse
No announcement yet.
36 inch unicycle beginner learning diary
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • 36 inch unicycle beginner learning diary
    Hi ,
    My learning journal of 36 inch unicycle
    Short summary I had 20 inch unicycle but in beginner level and give a break for years. A month ago got a 36 inch nimbus nightfox unicycle, 137 mm crank and start learning. Each day is like 20-30 minutes and used a tennis area fence to help me,
    Day 1-11 36 inch Beginner Learning Diary :
    Day 1-2-3 :Tennis fence holding
    Day 4-5 :still tennis fence +I can have 1-2 revolution
    Day 6 :It was the first day that all of a sudden I went 5-6 rev (3 times)
    Day 7-8 : lost it , again 2-3 revolution and turned back to tennis fence
    Day 9-10-11 got it again, but maybe max 7 rev, it is like a clock, when I come to 6th-7th rev I UDP, my body just gives up.
    Below is my youtube video showing Day 1-11
    https://youtu.be/ndUmKlDhwDU
    Thoughts :
    ** 36 inch Nimbus nightfox, crank is 137 mm, I use knee, shoulder, elbow, wrist protectors and also hill-billy short and helmet of course, if I could do I could wrap myself in bubble.
    **I wrapped a sock to the front and back so when it falls it doesnt crack the holding plastic part of the unicycle.
    **I took out the handlebars while learning, also wrapped the brakes.
    **Mentally got afraid of uncontrollable back falling, kind of happened twice, when I was trying to keep my weight in seat, the seat goes forward and I kind of falling back, scary feeling
    **I knew 20 inch unicycling although a newbie but gave 2-3 years brake after achilles rupture injury(not related to uni), so 36 inch feels I am learning again and mentally more scared of falling or hurting myself and it also feels really high !
    ** just ordered 150mm crank as recommended so I guess soon I will be practicing with them, with the hope of I could have more control
    Beginner Newbie Unicyclist:
    36 inch Nimbus Nightfox, 137 and 150mm crank
    26 inch Nimbus Muni, 125/150 mm KH crank
    20 inch Nimbus Trail, 137 mm crank
    https://www.youtube.com/user/unisiklet/videos
  • #2
    Enjoy your adventure! Here's a terrifying reality: a 36" wheel will be more stable and easier to ride if you increase your speed past "walking speed". Speed is scary, so that's tough to do as a re-beginner. I'm glad you're well padded. You are wise to remove the handlebar, which would probably be scarred and bent during the learning phase. It may prove useful in the hazy future. Good luck! Keep us posted.
    Comment
    • #3
      Originally posted by UnderTheLake View Post
      Enjoy your adventure! Here's a terrifying reality: a 36" wheel will be more stable and easier to ride if you increase your speed past "walking speed". Speed is scary, so that's tough to do as a re-beginner. .
      Totally understand and you are right,couple of times I had more speed and it seems much balanced. I hope I can pass my fear, and my fear began to focus more that ; I will be caught to the saddle and go backwards hitting my head (my mind plays all bad scenarios). And thank you for your motivation,really means a lot to a newbie
      Comment
      • #4
        doing just fine : ) I can't tell very well from the video, but it looks like you may be putting too much weight on the pedals. Indeed, like learning all over again. Sometimes its easier to focus on pulling your back leg up rather than pushing down with your front leg. That may give you a smoother pedals stroke. You're doing all the right things though.
        Steel is real! => I ride a Nimbus!
        Comment
        • #5
          Originally posted by juggleaddict View Post
          ......... Sometimes its easier to focus on pulling your back leg up rather than pushing down with your front leg. That may give you a smoother pedals stroke........
          Thank You ,definitely will try that!I told myself I have to keep weight in seat but my fear of getting caught up on the seat makes me put on pedals like I am closer to the ground feeling, I had to get rid of that thought. I will definitely try the pulling back leg up ! Thank You!
          Comment
          • #6
            If you want to do it the hard way that's fine, we unicyclists often do. Otherwise, see if you can make it down to the NYC Unicycle Club, or otherwise get your hands on a 20" or 24" unicycle, if even only for a few hours. It'll come back to you much faster, and cut way down on the scary time of learning on the 36".
            Until that happens, make sure you have plenty of air in the tire; they are very grippy and sluggish, so higher pressure will make them easier to twist and move. And make sure the seat is at a proper height; don't ride with your legs bent too much, because it will wear you out fast.
            John Foss
            www.unicycling.com
            "Who is going to argue with a mom who can ride a unicycle?" -- Forums member "HiMo"
            Comment
            • #7
              Looking Good
              As I start off ( mines a 32”) I always have to tell myself ''bum on seat, bum on seat'' as my legs never seem to want to bend.
              Comment
              • #8
                Originally posted by johnfoss View Post
                ......... or otherwise get your hands on a 20" or 24" unicycle, if even only for a few hours. It'll come back to you much faster, and cut way down on the scary time of learning on the 36".
                Great great recommendations, my tire air seems low ,I will increase it and I will practice on a small unicycle as well.The seat height and knee bends are that I am not so good of,maybe I should experience and see and will follow your tips; Really appreciate your recommendations,thank you
                Comment
                • #9
                  Originally posted by Alucard View Post
                  Looking Good
                  me too, the only thing is I feel not in control when I sit on the seat as when I go down ,don't feel in control,couple of times I went backwards,felt scary !
                  Comment
                  • #10
                    It is easier to mount the uni when the tires aren't too hard. I always ride between 30 and 35 PSI. I know the tire recommends 35-65, but I haven't experienced any issues. The 32" and 36" have road tire profile, which already makes them easier to turn, compared to the muni's
                    Comment
                    • #11
                      Great progress, Unisiklet. I agree that a smaller wheel will accelerate your progress. You are able to, on a smaller wheel, recover more easily from a greater imbalance, compared to the 36", where there is a small margin of imbalance before you UPD. IMHO, weight on the seat comes naturally over time and should not be rushed, especially if it means falling on your butt. Practicing idling on a smaller wheel (whether or not you can do it unassisted) helps in making corrections when the wheel gets out in front of us. I watched your video. This probably doesn't apply any more (since you're progressing quickly), but avoid sticking your fingers inside the links of the chain link fence. I'm speaking from experience. Luckily, I didn't injure myself. Keep practicing!
                      Comment
                      • #12
                        If you’re going to try a smaller wheel do it soon. Once you get the hang of the 36er you’ll be past the point of no return and won’t have eyes for any other wheels .
                        Unicycling is the fountain of youth.
                        Comment
                        • #13
                          Thank You, the tennis fence finger sticking reminder is awesome as I kind of see how it can happen and how dangerous it could be, will change my holding,thank you! and I will start the idling on a smaller wheel
                          Comment
                          • #14
                            makes sense, so I will try both ! thank you
                            Comment
                            • #15
                              Scared I'm scared
                              My fear was only overcome by raw determenation. I too fell twice backwards and that put the fear in deep. I put a mouse pad in my pants and it help remove some of the fear.
                              Two things worked for me.
                              First: get off the tennis court because it has mental stopping points. Go to a long sidewalk where you just look ahead and go.
                              Second: look around at people, trees, house, anything to help get your mind to not think about falling.
                              Cheers!
                              "Knowledge is gained right after you needed it the most"
                              Comment
                              Working...
                              X
