Announcement
Collapse
No announcement yet.
Nimbus Hatchet questions
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Nimbus Hatchet questions
    Hello Everyone,
    The Nimbus Hatchet has gotten my attention...
    because I think it looks really nifty!!!
    Does the shape of the post change anything about the way it rides?
    Or does it just change the way it looks?
    Would that unicycle be appropriate for street riding? (26")
    Since I am a "lightweight" would it be more difficult to manage?
    Thanks!
  • #2
    I think they made the frame that shape to avoid knee knocking on the frame.
    Quote Uni57: Unicyclists are the nicest people! Both on and off the Internet.
    Comment
    • #3
      As Juni said, the frame is mainly shaped to get out of the way of your legs, while still accepting a 5"+ wide tire.
      The 4" tire means it's closer to a 29er diameter than a 26, and it's a really great size for cross country riding. For the road or pavement, you may want a smoother tire. The Nate definitely rumbles on the road.
      If you're going to be in traffic, a 36er is all I feel comfy with because it gets me the speed to keep up with traffic, but I have seen people ride 29ers on the road too.
      Even small riders can handle a very large wheel, it's just a different feel, and typically a very large wheel like a 36 takes a little while to learn mounting.
      If you like the way the hatchet looks, but want something for street, check out the surly black floyd tire. It will still do grassy or light off-road riding where you don't need as much grip, but you'll have to pump up the tire quite a lot not to have issues with auto-steer, which can greatly affect the steering and camber effects on a unicycle.
      Steel is real! => I ride a Nimbus!
      Comment
      • #4
        The point of the frame was to be able to run a fat tire (which requires a bunch of frame clearance, so the frames normally stick out pretty wide) and minimize knee clearance. I think the fat tire revolution is more about snow and off road use, the big tire and rim are probably not the greatest for road riding. It's a beefy uni, wide hub, big rim and fat tire... It may be a handful to ride and have a mind of it's own, but if you like the way it looks and want it, go for it. Just keep the box so when you sell it here (to me) you can ship it.
        Comment
        • #5
          If you think a Monster Truck is appropriate to go grocery shopping, then why not!
          Comment
          • #6
            One tire I've been tempted to try on my Hatchet is the new Vee Apache slick. Should roll well and minimize auto steer.
            http://veetireco.com/listings/fat-ti...e-fatty-slick/
            Comment
            • #7
              Keep in mind that most of the fat tires are not auto-steering because of the tread shape but because of the low pressure deformation.
              This slick tire looks nice and may prove more affordable than the Surly Black Floyd. Don't be shy on the pressure and it will be a blast
              => CrMo 29: KH XC rim, Nimbus CrMo hub, Spirit 110/137 & Schwalbe Big One
              => Flansberrium 26: Nextie rim, JumboJim 4.0, Spirit 127/150mm, M4O ISIS
              Comment
              • #8
                First time I see a slick fat tire.
                Does anyone know if it exists in 29+ size?
                It would be a good alternative to the knard for my g29 since I ride it more often on urban conditions than on muni.
                By the way, sidd is right, autosteer mainly depends on pressure, when I inflate my knard 29x3 at 32PSI it almost behaves like a road tire.
                See here: http://unicyclist.com/forums/showpos...&postcount=395
                - Geared kh36 + Nightrider Lite + Kh Tbar + HS33
                - Qu-ax 36" + nightrider +Q-handle+ cable rim brake
                - kh 29" + knard 29x3+ kh Tbar + HS33
                - Qu-ax trial 19"
                -24"&26" wheels and forks and spare stuffs.
                Comment
                • #9
                  All very enlightening!
                  I just thought it was for looks!
                  Thanks everyone!
                  Comment
                  • #10
                    Did anyone ever get around to test the Vee Apache out on a Nimbus? I am tempted to do it but don't know about spacing issues and also if I am out and it starts to rain I can only imagine the hell I would be in for with a perfectly slick tire.
                    Still, I love my fat unis and this would be a nice thing in the right conditions.
                    Comment
                    • #11
                      According to Sheldon Brown the Apache should do OK in the rain or at least it shouldn't do any worse as long as I stick to the road.
                      http://www.sheldonbrown.com/tires.html
                      Tread for on-road use
                      Bicycle tires for on-road use have no need of any sort of tread features; in fact, the best road tires are perfectly smooth, with no tread at all!
                      Unfortunately, most people assume that a smooth tire will be slippery, so this type of tire is difficult to sell to unsophisticated cyclists. Most tire makers cater to this by putting a very fine pattern on their tires, mainly for cosmetic and marketing reasons. If you examine a section of asphalt or concrete, you'll see that the texture of the road itself is much "knobbier" than the tread features of a good-quality road tire. Since the tire is flexible, even a slick tire deforms as it comes into contact with the pavement, acquiring the shape of the pavement texture, only while in contact with the road.
                      People ask, "But don't slick tires get slippery on wet roads, or worse yet, wet metal features such as expansion joints, paint stripes, or railroad tracks?" The answer is, yes, they do. So do tires with tread. All tires are slippery in these conditions. Tread features make no improvement in this.
                      Comment
                      • #12
                        I haven't tried one yet- still wearing out my Lou. The Apache is smaller than the Snowshoe 2XL so it should fit without issue.
                        Comment
                        • #13
                          Thanks Paochow. I think I am going to put an Apache on my Large Marge for the 2 months of nice weather we get and then use a Snowsnow on a Clownshoe when the snow returns.
                          Comment
                          • #14
                            I've often wondered about this. My wife's recumbent has a 20" front tire (for pavement) that has a fine crosshatch tread pattern. It occurs to me that a completely slick tire might weigh more than the equivalent tire with the same amount of "tread" on it. This because the tread has no gaps or grooves in it, meaning more material. So they probably just make it a reasonable percentage thinner, to make up for the difference. But unlike a tire with tread on it, it's probably hard to tell when a slick tire is wearing out until you see threads. That's why maybe I feel more comfortable having some type of tread on my tires.
                            John Foss
                            www.unicycling.com
                            "Who is going to argue with a mom who can ride a unicycle?" -- Forums member "HiMo"
                            Comment
                            • #15
                              I have this tire. https://www.schwalbe.com/en/road-rea...e-big-one.html
                              The thread may as well be a slick and the tire balloons a fair bit.
                              -Philip
                              Comment
                              Working...
                              X
