Announcement
Collapse
No announcement yet.
Geared hub improvement
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Geared hub improvement
    [ame="http://www.youtube.com/watch?v=vbU1afvCRwc"]http://www.youtube.com/watch?v=vbU1afvCRwc[/ame]
    Do you think this idea could be used for a geared hub?
    I'm not sure if the wheel not spinning on its own would be a problem or not, it might lead to some spectacular UPDs, but so would a freewheel unicycle. Definently a cool idea, not sure if it is practical, but somebody smarter than me would have to decide that.
    ... and nipples, never forget the nipples.
    Saskatchewanian
  • #2
    That's not an original idea at all, we use that type of gearing in pumps and meter systems. Google image search "gear rotor pump" and you can see this. It's not really an improvement over a planetary gearing system because of all the vibration, grinding and noise that it introduces. It also requires the inner gear to be off center which is a problem for a unicycle hub unless you want to look like a kangaroo while riding.
    I'm convinced that the real reason we don't have a better hub is that we're too much of a niche. If there was a large market for them they would exist.
    Comment
    • #3
      I didn't know that, but now that I think about it, its not really surprising.
      Saskatchewanian
      Comment
      • #4
        a 1:27 reduction... Because unicycles aren't low-geared enough!
        “It is well known that a vital ingredient of success is not knowing that what you're attempting can't be done. A person ignorant of the possibility of failure can be a half-brick in the path of the bicycle of history.”
        Comment
        • #5
          You mean unicycle hub? Maybe, if you want tens of pedal rotations for one wheel revolution. By its very nature, this gear can only gear down. and then again only with quite large ratios.
          Edit: why does your thread title say Geared hub improvement?
          Comment
          • #6
            Not if you just hook it up the opposite way.
            Comment
            • #7
              To make it spin backwards?
              Comment
              • #8
                Then it's self locking. You could not propel the wheel pedaling. But you could roll down a hill and your pedals will move one revolution every 56m (on an 26") That's like freewheel with non constant pedal position ... haha
                Or thought otherwise .... it's like shortening the cranks by that gearing factor ... 125mm cranks will feel like 4.6mm cranks ...
                What a great improvement ... I wonder why Florian hasn't built up one yet ...
                Einradfahren in Sachsen:
                einradsachsen.com
                f/EinradSachsen
                07.06.2020: Europamarathon
                Comment
                • #9
                  This makes me think: you can't even roll the unicycle without pedalling (in gearing down configuration as the original poster proposed). The wheel will lock if you don't pedal.
                  Comment
                  • #10
                    Right.
                    Just like an automatic locking brake
                    A real improvement. Your uni will stop automatically when you upd and not ride away without you
                    einradsachsen.com
                    f/EinradSachsen
                    Comment
                    • #11
                      I wonder what happens if you momentarily don't pedal. Like if you change the direction of the driving force (as happens all the time during riding, to keep balance). Will the wheel lock already? Verrrrry tricky machine!
                      Comment
                      • #12
                        Isn't that what happens with normal fixed uni's...?
                        Comment
                        • #13
                          I don't think so. When you stop driving the pedals in a normal fixed uni (or a Schlumpf geared one, for that matter), i.e. you apply zero torque input, the wheel drives the crank set. In this hypothetical downgeared uni, if the pedals are not driven, the wheel locks. That is, it cannot rotate with respect to the frame.
                          Comment
                          • #14
                            So more like riding with a coaster brake (Or any other sort of brake that automatically activates when you aren't pedalling forwards) Sounds like a surefire way to break a nose.
                            Comment
                            • #15
                              Well, the good thing is that with downgearing of a factor of 27, the typical riding speed would be 0.5 to 1 mph. So it's not that dangerous.
                              Comment
                              Working...
                              X
