Announcement
Collapse
No announcement yet.
Disc Brake on 29 Nimbus Nimbus 36H ISIS Hub
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Disc Brake on 29 Nimbus Nimbus 36H ISIS Hub
    Hello Everyone,
    Sorry if there is a forum about this already.
    I have a Nimbus 29 road unicycle with Nimbus 36H ISIS with a hardened CrMo splindle,100mm center bearing to center bearing. I saw a Magura MT -2 disc brake for 70 bucks at my local bike shop and was curious if it would fit my unicycle hub or if I had to but a new hub and Nimbus D brake mount.
    I don't think it would work unless I get a new hub but let me know what you think
    Link to the uni on unicycle.com http://www.unicycle.com/nimbus-29-in...-unicycle.html
    Thank You,
    Captain Scott
  • #2
    You don't need to put in a new hub to use those, you can use Kris Holm spirit cranks which have a disk mount on them. You will also need a nimbus D-brake mount to go on the frame. Unfortunately the cranks will be quite expensive, over $100 but that's still much easier than putting a different hub in your uni.
    Comment
    • #3
      It might be an old photo on the site, but it shows Magura rim brake mounts already on the frame. So for the same $100 you could buy a set of Maggies and you'd be all set. (You would also need the brake mount for under the seat, but you'd need that in either case. And they're only a few dollars.)
      Just a suggestion.
      "I'm a unicyclist. I make my own reality."
      Comment
      • #4
        Thanks guys for the help I guess I will not get them.
        I will look into the Magura rim brake as i could also attach it to my Kris Holm T Bar.
        Comment
        Working...
        X
