Announcement
Collapse
No announcement yet.
Nimbus 24" Muni with Berm Master 24x2.3" tire
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Nimbus 24" Muni with Berm Master 24x2.3" tire
    When I went to replace the Duro wildlife leopard 24x3" with the Berm Master the tube seemed to bunch up. Do I need to get a new tube to use the Berm Master or is it ok that it is bunched up?
    Thanks in advance!
  • #2
    it wont make any difference.
    If anything, the tube is now more puncture resistant.
    The only downside to a slightly larger(wider?) tube would be the extra rotational weight, which you probably don't care about on a 24" MUni anyway.
    Comment
    • #3
      Thanks in advance!
      I would not use the original Duro tube for this tire any more. that beast is far to heavy (around 400g) and also way to big for a 2.3" Tire. Its designed for 3" or bigger. Also the Duro tube is very stiff which causes a huge rasistance to rolling. It matches ok with the 3.0" wildlife (but I also removed it and went tubeless which is way lighter and rolls way better) but for a 2.3" tire thats simply too much rubber.
      Take a Schwalbe SV10 or something similair.
      Einradfahren in Sachsen:
      einradsachsen.com
      f/EinradSachsen
      07.06.2020: Europamarathon
      Comment
      • #4
        I didn't know you could get a Berm Master smaller than 24x3. If it really is a 2.3 I would not use the Duro tube. If it is like my tire the Duro should be fine in it. I used a Kenda DH tube in mine originally, but for at least a few years I have had a 26" MTB tube in it.
        Are you sure it is a 2.3?
        "A properly ridden unicycle is like an object in orbit: constantly falling but never landing." -Diogenes
        Comment
        • #5
          Yeah, I didn't realize there were different sizes, but it is a 24x2.3 inch tire. So it looks like I need to go and get another tube. Is there anything in particular I need to look for when getting a tube? If the Schwalbe SV10 is there I will get that one but if it isn't is there another one that will do?
          Thanks for being such a supportive forum!
          Comment
          • #6
            Hmm. That looks like it might be a different tire altogether. Is it a Felt tire? The Felt Berm Master that gets attention on this forum is a round profile cruiser tire that has a knobby tread like the old Carlisle Aggressor MX tires from the '70's. The logo has a black and white checkered flag in it.
            Comment
            • #7
              ... Is there anything in particular I need to look for when getting a tube? If the Schwalbe SV10 is there I will get that one but if it isn't is there another one that will do? ...
              Look for a Schrader Valve (AV) or Dunlop Valve (DV). Sclaverand (SV) will be to narrow for the rim. And it should fit ETRTO 60-507 or at least 57-507.
              You can also take tubes from other manufacturers. But I made the experience, that schwalbe tubes keep pressure longer than others. With my conti tubes I often have to reinflate.
              einradsachsen.com
              f/EinradSachsen
              Comment
              • #8
                He surely has the Duro Berm Master
                einradsachsen.com
                f/EinradSachsen
                Comment
                • #9
                  Unfortunately, Eric is right I do have the duro berm master as opposed to the felt berm master. Does anyone have experience with the one from duro? Should I try and return it?
                  Comment
                  • #10
                    Does anyone know where I could order a felt berm master in California?
                    And should I consider the CST Cyclops since I am going to start mostly on the street before progressing to offroad? (could I use the 24x3 tube with it?)
                    here is a link to the one I was looking at: [ame="http://www.amazon.com/CST-Cyclops-Tire-2-4-BLK/dp/B002SG174M"]http://www.amazon.com/CST-Cyclops-Tire-2-4-BLK/dp/B002SG174M[/ame]
                    Comment
                    • #11
                      You can buy the Berm Master directly from Felts website following this link. Also if you have a Felt dealer in your area you can pick one up there (although they may have to order it anyway). I bought mine from our local dealer who happens to stock it. The price was the same as the online price at Felt, $24.99.
                      The Cyclops is a great tire as well. I would consider both of them great for paved surfaces, but the Felt tire will give you a little better offroad capability. If you plan on having one tire to cover all terrain you can't go wrong with the Berm Master.
                      As for the tube fit, I don't know what Duro tube you have, so it's hard to say. IF you have a tube that is 2.5 on the inside of it's range it should be alright in the Cyclops.
                      Comment
                      • #12
                        The tube is a duro, 24x3.0 inches so I guess it wouldn't work then.
                        The site you linked to won't let me add it to my cart (so I can't order it online) and there does not appear to be anywhere near me that stocks it. Is there another tire similar to the felt berm master? Right now I am thinking I will go with the cst cyclops and then see where I stand in a few months.
                        Comment
                        • #13
                          I hope that doesn't mean it is being discontinued. Maybe they are just out of stock at the moment, and they are pushing customers to shops who have inventory on hand.
                          I honestly don't know of another tire quite like the Berm Master. When I found it in the first place it had no reviews as a uni tire, and I took a chance on it.
                          The Cyclops is very much like the Hookworm. I think the rubber compound is a little harder, so not at sticky, but better wearing than a Hookworm. The construction is very similar though. While the tread pattern is different, the practical functionality is the same. For the price you really can't go wrong with the Cyclops.
                          Comment
                          • #14
                            I decided to get a CST Cyclops and a tube that fits from niagara cycle.
                            I am going to be riding on the street a lot in the beginning and once I decide to start to going off road more, hopefully the FELT berm master will be in stock.
                            Thanks all for the help and advice.
                            Comment
                            Working...
                            X
