Announcement
Collapse
No announcement yet.
huni-rex
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • huni-rex
    http://www.unicycle.uk.com/26-huni-r...att-black.html
    has anyone bought one of these unicycles?
    now there is a price drop from £495 to £180 im very tempted
    http://www.youtube.com/user/HuniRexUnicycles
  • #2
    I think the main issue was hpedal strikes-rex.
    I'm different, yeah I'm different. I'm different, yeah I'm different. Pull up to the scene and my wheel is missing. Pull up to the scene and my wheel is missing.
    Comment
    • #3
      In theory they sound decent for commuting/city riding... Fast as (Faster? I dunno what they gear up to) a 36er, but small/carryable as a 26er... Pedal striking sounds like a pain but if you're only riding it on the road anyway, what're you going to strike?
      Sadly I've never really found any real information on these things. They look cool, though I wonder if the cranks can become mis-aligned as they're not attached to each other...
      “It is well known that a vital ingredient of success is not knowing that what you're attempting can't be done. A person ignorant of the possibility of failure can be a half-brick in the path of the bicycle of history.”
      Comment
      • #4
        wow... i thought they dropped to that price to be discontinued.
        I've had a ride on a huni and it is a weird beast and a pig to mount. Imagine riding only in top gear on a schlumpf but unlike on a GUni, you are stuck with a 39er wheel the whole time and the rollover ability of a 26. The crank position feels a little weird but can be got used to. Due to the gear up, the wheelset feels ~50+% heavier than it really is.
        Pedal strikes were not a huge issue for me as it turns like a oil tanker.
        What it does do is GUni or 36er speed on the cheap in a smaller package. Most of my dislikes of this could be worked through by a determined rider and the reward offered of scalping b*kes on the morning commute is sometimes too good to miss. If you are planning on buying this, put a foss tube in it and maybe even find the lightest tyre that feels ok, it should make it more manouverable.
        If you want crazy though, i knew a guy who took one of these, stretched the frame and shoved a 36er wheel in it.
        Comment
        • #5
          PLEASE Find pictures/other such media to share about that, that sounds awesome! (And presumably minimised the pedal strike issue too?)
          Comment
          • #6
            i bring you the messiah of madness
            now get your jaw off the floor, you're drooling on the carpet.
            Comment
            • #7
              Trust me, I'm doing far worse than drooling.
              On a serious note... Some people already struggle reaching 36er pedals... How much lower are these ones??
              Comment
              • #8
                well...
                165mm cranks = 5.5"
                ~4" from hub to crank axles
                18" hub to top of wheel
                6+" for top of frame and saddle
                Looks like it needs a minimum inseam of 32.5+ With some modification, maybe a 30" inseam would be possible.
                On the other hand the frame looks like it could take a 700c wheel to make a monster race unicycle without modification. Another easy change would be to swap out the drive sprockets to give a different gear ratio.
                Comment
                • #9
                  wow that 36er looks amazing can you buy them ?
                  Comment
                  • #10
                    36er geared
                    just found another geared 36er like huni developed by Pete Perron
                    http://randomascii.wordpress.com/201...red-unicycles/
                    Comment
                    • #11
                      The guy had the frame extended as a custom job. You could have it done for yourself if you can find a metalworking shop or bike builder that think they can do it. Thing is though, once you factor in the costs (labour, new parts, metal stock), you might as well buy a brand new oracle instead. Also if they don't get it just right, the frame could suddenly fall apart at 20mph...
                      I would consider this and the purple phaze/red menace V36ers as an exercise in what CAN be done rather than what SHOULD be done. A permanent 54" effective diameter gives a very high gear with any length cranks. Almost any UPD on a uni like this (due to high minimum speed to keep stability) is going to be too fast to run out. Starting up and coming to a stop would be hugely difficult. With a 2 gear 36, the low gear allows for much safer low speed manoeuvring.
                      Comment
                      • #12
                        Post #11 in this thread shows a 29" wheel in a Huni-rex.
                        http://www.unicyclist.com/forums/sho...d.php?t=110920
                        There have been a fair number of fixed-gear uni designs posted on the forum, of various types. The main drawback that is common to them is the fixed nature of the gearing. The Schlumpf has gained popularity (I think) because it can be shifted on the fly, and it maintains the same basic riding mechanics as a regular unicycle.
                        "I'm a unicyclist. I make my own reality."
                        Comment
                        • #13
                          29er (or skinny 700c) Huni sounds like fun, and sounds like fast too I'm almost tempted to buy one now and re-lace it with a 700c rim... When I get a job maybe
                          Comment
                          • #14
                            That is my impression also. Do we have reason to believe there will be future production of these?
                            The 36" version probably eliminates the worry of pedal strikes, but the drawback, already discussed, is that it's high gear only. Fine for flat rides, not so great for hilly places. But still hugely cheaper than anything with a Schlumpf on it.
                            The majority of my UPDs on my Schlumpf, not counting ones during shifting, have been in high gear. Fortunately they are almost always at lower speeds. That's partially because it's harder to ride it slow than fast. A 36" Schlumpf also gears up to 54" and, while difficult, I have gained a lot of confidence maneuvering it even when going slow in the high gear. It's much more stable and manageable once you get over 10 mph/16 kph.
                            John Foss
                            www.unicycling.com
                            "Who is going to argue with a mom who can ride a unicycle?" -- Forums member "HiMo"
                            Comment
                            • #15
                              I was riding Huni-rex at EUC some years ago and I did not like it. It felt really strange and sluggish and pedal strikes happened often on a track that was set up due to tight turn. Also cranks were going out of sync sometimes, but it was easy to tighten and resync them.
                              But...
                              first, there were some changes to the construction later and I've heard cranks going out of sync is not a problem anymore (or at least not that often).
                              second, I was riding it before trying guni, so I was not used to riding in high gear. It would probably feel much more natural for me now.
                              third, the original price was way too high for such limited application. But the 180 pounds sounds like a fair price.
                              fourth, I like the idea of having it 700c'ed. This could be a nice uni for commuting.
                              http://vooni.kkdt.org My unicycling adventures including RomUni ride.
                              Comment
                              Working...
                              X
