Announcement
Collapse
No announcement yet.
Qx series frame with KH Moment Hub
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Qx series frame with KH Moment Hub
    They're not "supposed" to fit but it's a matter of mm. Has anyone made them fit by grinding the bearing holders and the bearing holders on the frame?
  • #2
    Originally posted by emile View Post
    They're not "supposed" to fit but it's a matter of mm. Has anyone made them fit by grinding the bearing caps and the bearing holders on the frame?
    Is that what u meant?
    Yes but not on that particular frame, I forget which one (K-1 XTP?)
    Ride everywhere and never just ride anywhere. If you can ride where you are going within a hour, do it, and if you can do a trick 50-75% of the time do it along the way.- Bob Burnquist
    What's next?
    Learn2Ride&doTricks
    TrialsClasses&Building
    Comment
    • #3
      i had a quax frame on a moment hub. your all good
      Roses are red, violets are blue, may I procreate with you so I can ride a g32!! - Alan hogan
      Comment
      • #4
        My QX frame wasn't compatible with KH hub + Spirit cranks + disk brake because the bolts that hold the disk were rubbing the frame. Without the disk brake it would have worked.
        Comment
        Working...
        X
